Low compression
Old May 4, 2020 | 12:28 PM
  #31
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably warped the head, these blocks are pretty stout. All it takes is one overheat to warp heads, at least you found where the problem is coming from though.
Old May 4, 2020 | 12:52 PM
  #32
Anthony gamez's Avatar
Needs work
The previous owner overheated the engine enough to melt the knock sensor in the middle between the heads. so I'm not sure
Old May 4, 2020 | 06:59 PM
  #33
cleric670's Avatar
BANNED!!!
Damn that's SERIOUSLY overheated lol.
Old May 4, 2020 | 08:25 PM
  #34
Needs work
So what do y'all think deck still good?
Old May 4, 2020 | 10:31 PM
  #35
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Now thats something you don't see every day. Post a pic?
Old May 4, 2020 | 11:27 PM
  #36
Needs work
Let me check on my photos
Old May 5, 2020 | 12:11 AM
  #37
cleric670's Avatar
BANNED!!!
Until you break the engine down there's no way to know if it's straight or not but a compression test and leakdown test can help determine if anything is REALLY wrong.
Exhaust gas checking the coolant can tell if it's pushing exhaust past the HG, coolant sucking into the HG shows up on plugs same with oil.
Old May 5, 2020 | 04:53 AM
  #38
Needs work
Sorry cleric missed your response I put new/used heads with the new headgaskets. Well I did a compression test early messages show the psi in each cylinder. Very low
Old May 14, 2020 | 08:05 PM
  #39
chasracer's Avatar
It's possible that you have a leak or screwed up something replacing the headgasket but I would also be on the lookout for cracks between the cylinder wall and water jacket.
Old Jul 5, 2020 | 01:42 AM
  #40
Needs work
So funny story guys. I pulled my motor and hung it up. Drained the oil first couple seconds oil, then BAM coolant pouring out. Car ran fine without coolant but as soon as I introduced coolant to the block nada. So my question is how do I take the dang crankshaft pulley bolt off. Tried impact gun. air impact gun. Breaker bar. Nothing will break it loose.
David Port
Feb 23, 2020 02:43 AM
03G35SEDAN6MT
Mar 4, 2018 09:46 AM
ZBigKahuna
Dec 20, 2017 03:03 PM
Reckless_G
Oct 23, 2017 12:24 PM
VQ Hotness
Nov 6, 2010 02:41 AM
