2007 Infiniti G35 Sedan not starting
If your fans come on when you are in acc mode, that sounds like the fail safe mode when there is a problem on the CAN bus. If the modules can't talk to each other, the car doesn't know how hot it is so it runs the fans just in case. You need to get your codes read. You probably have a U1000 code for CAN comm failure from one or more of the modules. If one of the modules is bad and shorting the CAN bus, you can figure this out by removing the modules from the bus one at a time until the U1000 error goes away. Usually this fault will allow the starter to crank the engine but it won't start because the immobilizer isn't satisfied because it talks on the same communication bus. Start by having the codes read. If the car won't start to get you somewhere to read the codes, you're going to have to get a cheap code reader so you can do it at home or get it towed somewhere to get somebody to look at it.
khoacalacan
09-29-2011 08:28 AM
