Breaks lock up whilst barely applying pressure.
Old Jun 3, 2020 | 05:01 AM
Hmixon16's Avatar
Infiniti g35 6MT
So I have recently acquired my 05 g35 6MT, and since I have had it the abs slip and Vdc lights have been on. I found out the main fuse was blown so I replaced it, and once I did whenever I was to take a turn and apply the breaks slightly they would lock up completely, causing me to come to a complete stop and it would vibrate the car a lot. I put the blown fuse back in and it has not done it since. Does anyone know what the problem may be.
Old Jun 3, 2020 | 12:14 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Scan the car and find out what code it's throwing with the fuse in. What you're feels ng isn't "the brakes locking up" it's "the ABS pump turned on" which causes a severe shuddering feeling from the brake pedal and some noise from the engine bay where it's located.
You might just have a sticking ABS relay if it happen immediately when you first hit 10mph in the car. If it happens as soon as you touch the brakes I'm guessing an ABS wheel sensor bit every component throws a specific code.
Project 04
Apr 21, 2013 11:48 AM
NewGuyG35
Jun 23, 2009 06:30 PM
alphabetman
Jan 2, 2009 09:15 PM
SilviaVsSupra
Sep 24, 2007 02:41 PM
