Wiring For Reverse Lights And Neutral Position Sensor
Old Dec 21, 2020 | 07:10 PM
FrankenG's Avatar
5 Year Member
AT-MT swap Coupe
I am using my 5AT ECM. Do you think re flashing the ECM to 6MT would fix the PNP and reverse switches, or just get rid of the U1000?
Old Dec 24, 2020 | 12:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I've never done it before, talk to @seymore4 he would probably know.
I'm pretty sure that's the problem though, the 5AT ECM is looking for a TCM which isn't connected thus U1000, P1065 might actually be sent because of "no power to TCM".
Old Dec 24, 2020 | 01:39 PM
seymore4's Avatar
m56
There could be something else going on, but at minimum you need to flash the ECU for the 6MT swap. The ECU thinks its an automatic still so its going to give you all kinds of problems . I'll send you a PM
Old Jul 24, 2021 | 05:51 PM
southdown's Avatar
G35 sedan, with a 6 speed swap/marketplace coilovers/ebay short sifter, and a rocking sound system
Did you ever get your G sorted @FrankenG I did a 6 speed swap in my 03 sedan begining of this year, and was not so lucky to just send the ECU to get an Uprev tune. My ECU is the half year that is not supported....lame.
Old Jul 24, 2021 | 06:29 PM
FrankenG's Avatar
5 Year Member
AT-MT swap Coupe
@southdown The reverse lights are easy enough to hard wire, and once I got the car tuned to MT the cruise started working even without the pnp hooked up. I don’t think you’ll be able to get it working if you can’t tune it
Old Dec 30, 2021 | 10:08 PM
Infiniti/23's Avatar
4 dr auto silver base open diff. 6mt swapped.
Tcm
I have the auto trans still and currently doing the cd009 gen 2 swap into my 04 g35 sedan. Thinking I can just pull the tcm from the trans, plug it into the wiring, zip tie it to the side of the manual trans and as long as it sees neutral safety and shift lock it should work like an automatic motor to a manual trans, only thing is, it will think it’s in a different gear than it’s actually in and won’t adjust the iac accordingly when I push the clutch in. Usually there’s an increase in rpm because the car goes into idle mode between shifts and changes the torque stall speed to match the shifting revs. So when I push the clutch in to shift, it’ll either think it’s in let’s say, park or drive and continue the motor at it’s course instead of reacting to each shift like a manual ecu would. Anybody know how true this would be, or have an alternate solution that doesn’t require buying an ecu or reflashing one?
Old Dec 31, 2021 | 10:59 AM
cleric670's Avatar
BANNED!!!
The car will probably just limp mode because it won't see the turbine input/output speed data and will think the transmission is slipping or not functioning.
Old Dec 31, 2021 | 11:02 AM
seymore4's Avatar
m56
Just get the ECU flashed for the manual swap. It will make your life so much simpler
Old Feb 28, 2022 | 11:11 PM
shiesty_qfiddy's Avatar
G35 base coupe
Same issue
Why are you having to rewire stuff for a tranny swap?
Hey man what’s up? I just bought a 2004 Infiniti G35 2 days ago and I just found out yesterday that it was converted to manual and my reverse lights don’t light up when in reverse and also getting a P1706 (park/neutral position switch) and a U1001 (controller area network line malfunction) along with other codes. I’ve only been in the g35 game for about 4 months with my last G35 but it was auto. Please any information on how to get the reverse lights to work will be helpful like as description on where I can locate these sensors and how to run any type of wire. Thanks man 👍
Old Jan 6, 2026 | 09:52 PM
Etorre's Avatar
g35 coupe 2007 rwd automatic base model
I just finished up my 07 manual swap but it keeps saying to shift to park I can start the car but when turning off the vehicle it says to shift to park any ideas on how to fix that?
Kennycaine
Jan 1, 2020 11:04 AM
espifrankie
Dec 29, 2019 10:51 AM
painter8
Feb 9, 2014 08:30 AM
masterdave
Jul 13, 2010 03:53 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
