What is the little radiator behind the grill
Old Sep 13, 2020 | 07:26 PM
Siciliang35's Avatar
Right behind the grill there's a small radiator or some kind of cooler that sits in front of the coolant radiator what is that cooler called
Old Sep 13, 2020 | 10:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It should be dimensionally almost the same height and width as the radiator, it's the air conditioner CONDENSER. Some models of G35 it's actually all built together with the radiator (both components soldered together even though the look to be separate) and not separately replaceable.
Old Sep 16, 2020 | 04:41 PM
It's this small one behind the bumper it's leaking and it think it's power steering fluid
Old Sep 16, 2020 | 05:27 PM
cleric670's Avatar
BANNED!!!
Yep, power steering cooler.
Old Sep 16, 2020 | 07:18 PM
Where can I find the direct replacement OEM brand new I can't seem to find it anywhere
Old Sep 17, 2020 | 12:15 PM
cleric670's Avatar
BANNED!!!
It's not a wearable item so I would just buy a used one off eBay.
Probably got hit by a rock or some road debris that put a tiny dent/hole in it.
You can also remove yours, hook it up to an air compressor (cap off one end) to find exactly where it's leaking from, then solder the hole closed. You might have to bend the fins over just a little bit to get the torch on it better, just bend them back when you're done.
eBay has some for under $20 though so it's not like it's an expensive part.
johnson_vq
Sep 30, 2018 05:40 PM
tite_tite
31
May 4, 2016 06:25 PM
dimentio1
Mar 11, 2015 12:12 AM
arekieh
Oct 1, 2013 03:09 PM
WillJV
Sep 18, 2007 11:11 PM
