Speedometer Damaged?
Old Dec 24, 2020 | 09:22 PM
AnonG35's Avatar
Question Speedometer Damaged?
Bought a new car & the speedometer starts at 10mph causing my speedometer to be off. Any way to reset/calibrate the cluster?
I recently swapped the rear VSS & I'm on stock profile tires. Thanks.
Old Dec 24, 2020 | 11:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it's consistently 10mph off through the entire range then someone probably removed the needle and didn't put it back on correctly.
Put the cluster into diagnostic mode and take a pic exactly where the needle lands.
Old Dec 28, 2020 | 03:24 PM
AnonG35's Avatar
Old Dec 31, 2020 | 12:24 PM
cleric670's Avatar
BANNED!!!
You need to hold down the trip odometer button while in test mode so the needles all rise. Then take the picture.
EDIT: It's a fairly straightforward fix to reset the needles if someone did move them (EDIT: disassemble instrument cluster to get the front plastic cover off, plug it back in and then...), while it's in test mode and you have the trip button pressed you simply lift the needle off the stepper motor shaft then put it back on it the correct position. I'll try to get a picture uploaded later today of the correct position they should be in.
AbdullaJaafari
Mar 17, 2020 09:01 AM
dluttrell87
Aug 26, 2010 04:10 PM
turboedsupe
Jun 2, 2010 04:36 PM
Foques
Sep 29, 2008 08:27 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
