reverse light removal DIY??
Old Mar 11, 2005 | 04:45 PM
nthnbutaGthang's Avatar
Does anybody have one? I wanted to swap out my reverse light bulbs for some new ones and wanted to know if there was a DIY...I think there is a thread for it in the DIY section, but the link no longer works..as is the case with a lot of threads in that forum...thanks for any help..
Old Mar 11, 2005 | 04:55 PM
gspotter's Avatar
You have a sedan, correct? I think this should be in the sedan forum, not the coupe forum.
Old Mar 11, 2005 | 06:12 PM
no...i have an 04 coupe..i just want to change the bulb..not the whole taillight
Old Mar 11, 2005 | 06:35 PM
GonSpeed's Avatar
not 100% sure on this, but go in the trunk then peal back the material lining the trunk behind hte tail light, then unbolt it, then the light bulbs will come right out
Old Mar 11, 2005 | 08:44 PM
RST531's Avatar
Yes, you have to remove the taillights from the car in order to change the bulbs.
Old Mar 12, 2005 | 09:46 AM
so u are saying that the whole taillight has to come out just to change the reverse light lightbulb?
Old Mar 12, 2005 | 05:03 PM
GRider35c's Avatar
yes .
Old Mar 12, 2005 | 05:12 PM
klwoods's Avatar
yes that's correct. I've done it personally. It's simple...like 3-4 screws you'll see after peeling back the trunk carpet and then the assembly falls off into your hands. Simply undo the wire/back and replace your bulbs.
Old Mar 13, 2005 | 04:12 AM
BirdMan's Avatar
If you don't mind me asking, whats type of bulbs are they?
Old Mar 13, 2005 | 12:10 PM
i picked up some mtec reverse bulbs...also got the mtec domb light bulbs, sidemarkers, and headlights for the fogs..
Old Mar 13, 2005 | 06:42 PM
EricIsKlumzyee's Avatar
PIAA T16/W2 Bulb: Xtreme White - http://www.optauto.com/index.htm?stocknumber=PIA-19224
if you want PIAA reverse (i think thats the one) some one confirm
Old Mar 13, 2005 | 08:03 PM
i already have the mtecs...tried to get the taillights off today, but its too much trouble..that plastic back there is so cheap too..it cracked a few times..wht garbage..i'll prob just sell the bulbs..
Old Mar 13, 2005 | 08:13 PM
GonSpeed's Avatar
your not very good with your hands are you??
Old Mar 14, 2005 | 03:23 PM
BirdMan's Avatar
Can't really confirm thats the right bulb however I checked the tech manual and the wattage is exactly the same, so you're probably right.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
yassy
Aug 9, 2015 07:31 PM
newg37
Jul 26, 2015 09:32 AM
