Car won't start
Old Aug 26, 2022 | 05:28 PM
  #31
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The new Milwaukee M12 battery ones are badass, that's what we switched to at work.
Old Aug 26, 2022 | 11:38 PM
  #32
w_lap's Avatar
I didn't even think about soldering, or those solder shrink tubes. I just put the wires in butt connectors and crimped them down, I tried to put some heat shrink over it but it just covered the connector, so I will need to tape it up so nothing can get in there. I probably should have looked at better ways to connect it instead of using what I had on hand, but it all seems to be holding, it might not be pretty but it works haha
Old Aug 27, 2022 | 01:47 PM
  #33
cleric670's Avatar
BANNED!!!
Crimp butt connectors will work temporarily, but they will also wear out/corrode/loosen with time. Definitely not a permanent fix.
Old Aug 30, 2022 | 12:01 AM
  #34
w_lap's Avatar
Yeah and it really doesn't look good, the shrink tubs did not compress enough so it is definitely not water resistant. I will need to fix it with either those those tubes or solder, unfortunately I will be away for a while, so I will need to decide which one and fix it properly.
Old Dec 30, 2022 | 12:07 AM
  #35
Learres's Avatar
bmw
Moderator EDIT: Banned for botting a web based VIN search.
Old Mar 21, 2024 | 04:45 PM
  #36
deshaark's Avatar
2006 g35 base
single black/white wire hanging in fuse panel
Car won't start I have a single black/white disconnected wire hanging in fuse box. Where does it connect? Picture attached.
Old Mar 22, 2024 | 02:04 AM
  #37
Scorpi0's Avatar
That doesnt look like an original wire. Maybe someone used it to tap into power from the fuse box to something else. What is the other side connected to?
Old Mar 22, 2024 | 09:13 AM
  #38
deshaark's Avatar
2006 g35 base
Car won't start
Don't know what it's connected to. Attached a picture of direction it's going, somewhere behind the brake.
Old Mar 22, 2024 | 11:02 AM
  #39
G2B35AGN's Avatar
Hate to say it, but you need to keep following the wire. In your first pic, is that black electrical tape on a white w/ black stripe wire the end of the mystery wire? Was it just twist-connected to something and then wrapped with tape? Could it have come undone and that's what's caused the sudden no-start condition? Any aftermarket kill switch/security installation that's come undone? Keep us posted.
Old Mar 22, 2024 | 07:19 PM
  #40
Joramos1993's Avatar
Trying to revive the g
Replaced the solenoids I see one has a small tear maybe from the squirrels getting in or trying to make a home in the engine. Did oil change changed spark plugs changed the ignition coils still same codes. Any ideas ? Might change the throttle body next as well ?
Clang
Apr 9, 2022 12:37 PM
NateKeo
Jun 1, 2019 10:28 PM
WhtG3506md
Oct 28, 2011 03:02 PM
khoacalacan
Sep 29, 2011 08:28 AM
