HELP ME PLEASE! 03 G35 Sedan. Cranks but no start!?
Old Mar 28, 2024 | 01:58 AM
Mccallt's Avatar
G35 sedan
I am trying to get help so I'm resorting to this and maybe a fellow G person can help... I just replaced both camshaft position sensor and the crankshaft sensor after seeing on here that I should do all the sensors at the same time I will add that I tried parts store once to no avail so I went and ordered the Hitachi ones of RockAuto install them today and I'm still having the same problem the car will crank but doesn't start or even seem to be turning over to start the crank is strong and nothing else ever placed the plugs and the coils are good I'm not sure why it seems that I'm not getting spark or fuel but I can hear the fuel pump prime when I turn the key on I have checked the EVAP service port and there is no fuel that comes out I'm kind of lost any information or thoughts would be greatly appreciated and a little back info I had started with the sensors because right before my car took a s*** on me on the side of the road I had left AutoZone not 5 minutes before this because it was running like s*** and it had the code p0340 camshaft position sensor bank one and that is the last time I got a code right before it died and now there is no codes showing up I guess because I had the battery unhooked to do the work and I cant even get it to start to try reading new codes.. i hope maybe this is enough info to try getting some help on figuring out my problem. Any thoughts are greatly appreciated!! I don't want to give up on the G I've done everything myself and invested alot but I'm running low on answers and hope!!!
Mccallt
May 14, 2024 06:20 AM
Mnav13
Jul 28, 2018 10:44 AM
Maxmenov
Nov 12, 2017 07:28 AM
Jlaud
May 19, 2016 12:39 AM
EverybodyWildOu
18
Jun 18, 2012 12:25 PM
