Car won’t start. Please help!
Old Sep 6, 2022 | 11:43 AM
Turbski's Avatar
G35 manual
About a month ago I was driving my g, not hard at all or anything, and it just cut off. It will crank, but it will not start, so I plugged in a cheap obd2 reader that I have used on the car for a while, and it can’t find the ecm. Also when the ignition is turned on the fans come on at full speed. Which leads me to believe I have a dead ecm. Before I replace the ecm does anyone have anything I should try. I have already replaced the ipdm and nothing has changed. The previous ipdm showed signs of corrosion, and oxidation.
Thanks guys
Old Sep 6, 2022 | 01:26 PM
2003G35stock's Avatar
G35 Manual
Before you do anything expensive like buy a new ECM, first take your time and check all the fuses, you could have simply popped one that powers the ECM and so it stopped.
Second, if you check the pins on the OBD-II connector and the key is on, do you get anything from any pins?
Old Sep 11, 2022 | 07:17 PM
Turbski's Avatar
G35 manual
sorry for the late response, but I checked all fuses and they are good, I also checked the obdII connector and I got 11 volts out of 2 of them, 2 volts out of 2, and 4 volts out of one of them
w_lap
Mar 22, 2024 07:19 PM
Rainy
Sep 18, 2020 08:29 AM
Jonjon93
Nov 30, 2015 08:39 PM
jrhykushi
Mar 28, 2012 07:57 PM
ModMe
Jan 27, 2007 12:24 PM
