HELP!: Water Pump Bolt Extraction
Old Apr 8, 2023 | 05:31 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Likely the bolt made it all the way to the bottom.
Personally I would remove the lower oil pan and look up with an inspection mirror to see if the bolt is laying on the ledge right below the crank sprocket. That would be an easy quick fix since you can just reach in with a magnet and pull the bolt out. Would only take about 30 minutes to pull the lower pan and the oil pickup baffle and look up with an inspection mirror and flashlight AND put the lower oil pan back together. Lot quicker than the 4 hours or so to speedrun through taking off the timing chain cover, 8 if you've never done it before.
Solly
Apr 8, 2023 05:28 PM
humbalum
Aug 12, 2021 07:55 PM
michaelhuynh13
20 Inch
Apr 4, 2012 03:18 PM
OMG35S
May 6, 2011 12:58 AM
OMG35S
V36 Engine, Exhaust, Drivetrain & FI
May 5, 2011 09:38 PM
