Multi misfire won’t go away (p3000)
Old Dec 20, 2022 | 08:33 PM
350Kay's Avatar
2004 g35 de coupe
Recently my 04 g35 de shot a multi misfire code
I have done everything possible to try and diagnose/ fix it with no luck
(Motor was replaced at 130k)
replace spark plugs
coil packs
fuel pump/fuel pump sensor
a/f sensors
maf sensor
and valve covers aswell as the gaskets
brought it in to a shop for a ecu/ecm scan. wiring all checked out. But was told that the fuel temp is reading -45 degrees constantly (if that means anything)
What could possibly be left to fix on my G any help is appreciated!
Old Dec 20, 2022 | 10:50 PM
Scorpi0's Avatar
Did u do any work on the car right before this happened?
Old Feb 10, 2023 | 09:59 AM
Jorge Flag's Avatar
Completely stock besides headlights
replace spark plugs
coil packs
a/f sensors
maf sensor
have you tried with new injectors? Or maybe camshaft or crankshaft position sensors?
Old Feb 10, 2023 | 01:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it never worked properly after the swap I'd guess the shop who did the engine swap didn't line up the flywheel on the alignment dowel so the whole thing is reading wrong crank position.
Rj_frauenthal
Dec 20, 2023 03:20 PM
bmdubya1198
Aug 28, 2023 09:08 PM
VWownerwith1.8
Jul 22, 2022 11:01 AM
Tristan Laravea
Sep 27, 2019 02:52 AM
Terry_G35
Aug 3, 2016 04:06 PM
