Vdc off/ slip light after crankshaft replacement
Old Jan 3, 2023 | 07:14 PM
Kee4Key's Avatar
Great car just having problems with VDC OFF/SLIP LIGHT I just replaced camshafts and the crankshaft
I have a 2005 Infiniti G35 coupe has been a project car for a couple years. Now I’m trying to get my VDC /SLIP LIGHT OFF even after I’ve replaced the crankshaft position sensor and both camshaft sensors. Diagnostic test still says crankshaft position sensor PLEASE SOMEONE GIVE ME SOME FEEDBACK.
Old Jan 3, 2023 | 07:16 PM
coffeysm's Avatar
Is it an OEM sensor?
Old Jan 3, 2023 | 07:17 PM
Kee4Key's Avatar
Nope all three hitachi 🤦🏾‍♂️
Old Jan 4, 2023 | 11:08 AM
Urbanengineer's Avatar
Do you have a wheel speed sensor code?
Old Jan 4, 2023 | 11:16 AM
coffeysm's Avatar
Are you scanning for actual codes and troubleshooting? Also, do you know if your car has RAS on it? My RAS motor went out and caused some of those lights to turn on and I was able to fix it after replacing the RAS motor from a used part from an M35/M45.
Old Jan 4, 2023 | 05:36 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
RAS wasn't an option until MY 2006.
Old Jan 5, 2023 | 12:07 PM
Kee4Key's Avatar
No just my crankshaft position sensor A but my secondaries are my o2 sensors didn’t get them welded in yet ,manual mode switch/circuit and throttle position sensor/circuit A/T
Old Jan 5, 2023 | 12:14 PM
Kee4Key's Avatar
Right now Only reading codes and buying parts kinda new to this don’t know how to troubleshoot it yet
Old Jan 6, 2023 | 02:33 AM
coffeysm's Avatar
Post all the codes it shows if any and make sure you are using OEM or OE parts.
Old Jan 6, 2023 | 08:08 PM
Kee4Key's Avatar
I’m going to check the wires to the crankshaft if that isn’t the problem I will switch to OEM parts
CODES BELOW 👇🏾
Old Jan 7, 2023 | 09:22 PM
coffeysm's Avatar
I believe Hitachi is the OEM part maker. Check out Nicoclub and look up the FSM for your car and you can get better understanding troubleshooting tips. Your car does run though right? I think there are three wires on the sensor one should be ground, one goes to IPDM, and the other to the ECU. I am wondering if maybe that P1705 might be causing those lights to come on too.
Cabrito
Feb 6, 2022 05:21 PM
tacticsG35
May 3, 2020 08:47 PM
Chris Plowman
Jun 26, 2019 06:12 AM
digital sol
Jan 28, 2015 09:24 AM
geed up
Apr 16, 2011 03:24 AM
