G35 crank no start
Old Feb 27, 2023 | 08:17 PM
Xavier g35's Avatar
G35 coupe 6mt
G35 crank no start
G35 crank no start. It has no communication with the ecm but I somehow got 2 codes u1000 and c1136. Car was running really rought and after I pulled coil packs the car would not start after that. I’ve replaced the ecm twice and I think it may be frying them. Any ideas? Car started running rough a little after clutch was replaced. Also security light is solid red anytime key is in ignition
Old Mar 3, 2023 | 09:14 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
How are you programming the ECM/BCM and keys when you replace the ECM?
Solid red NATS indicator means the BCM doesn't recognize the key and this will prevent the injectors/coil packs from firing, this is likely your crank no start cause.
Are you sure you didn't mix up the coil pack harnesses? It's easy to do.
LegacyG35
Drivetrain
Jun 30, 2020 01:16 PM
Chrisrob8823
May 31, 2020 11:43 PM
RedG35Az
May 14, 2014 10:03 PM
alan17
Mar 1, 2014 08:13 PM
saliaga08
Oct 10, 2011 12:32 AM
