12Volt.Solutions Remote Start
Old Jan 6, 2024 | 04:40 PM
gkeylow's Avatar
Infiniti G35 Coupe (Stock)
https://volt12.s3.amazonaws.com/public/application/6cd3af1c-1715-4b82-9a50-ae6ccaeb3da2.pdf
https://youtu.be/hM3o_gM6Gd0?si=Es96a6OP3Rl8jmPQ
https://youtu.be/muZJ2066Hz8?si=jOdwKZPbqkWs6NFR
if not familiar, this PDF and two videos is what they give you for instructions on how to install. I’ve installed it correctly (I think), but now the engine only turns over and won’t start.
as per the PDF, I have attached to the purple wire on the white connector of my BCM. I’m here just to verify that the purple wire is the ignition wire that the trigger should connect to. I have all the manuals including the BCM manual for my G35, but it doesn’t give a color coated pin out
Any and I’ll help would be appreciated!
Old Jan 7, 2024 | 12:04 PM
gkeylow's Avatar
Remote Start Trigger Wire scotch locked to what 12volt.solutions claim is the correct wire to connect to
Old Jan 16, 2024 | 06:15 AM
SylviaBaker's Avatar
G35 Base Sedan
Thanks for sharing pdf file.
Spoiler
Old Jan 16, 2024 | 02:59 PM
jbarnett250's Avatar
Does that kit come with some kind of immobilizer bypass? My guess why it just cranks is that the immobilizer is preventing it from starting. I don't know what kind of indication you should get if the car doesn't sense the key fob. Maybe a red key light on the combo meter. When I had my car tuned, I had them disable the immobilizer so I wouldn't have to mess with that and to eliminate the possibility of any future problems with flaky immobilizer and key fobs.... made the remote start install easier.
Calvin12
Jun 3, 2012 12:55 AM
Boostedef
Jun 10, 2010 11:14 PM
nguy0750
Nov 9, 2009 02:30 PM
djamps
Sep 16, 2009 05:10 PM
Strtsk8r321
Mar 28, 2008 02:21 PM
