2006 G35 coupe AT Key won't turn in ignition
Old Feb 19, 2024 | 01:39 AM
L0NGJUANSILVER's Avatar
Infiniti G35 Coupe AT
How's it going guys new to this forum I have 2006 Infiniti G35 Coupe AT car was working perfectly fine a few weeks ago then go out to grab some food and car was dead I bought a new battery thinking it was maybe the battery still nothing , replaced the terminals on the battery still nothing. I just replaced the starter a few months ago and it didn't give me any problems starting. The car gets power lights and alarm turns on , doors lock and steering wheel did move til I moved it and it locked , I don't have the fob only the key just trying to get some tips or direction before I blow more money on stuff it won't need anything helps Thanks also when I put the key in the ignition dash stays the same no red signal or anything just dead
Old Feb 21, 2024 | 02:18 PM
Jemeu's Avatar
Some mods
Maybe try and rotate the steering wheel a bit while turning the ignition?
Old Feb 23, 2024 | 02:04 PM
the steering wheel was completely free not locked up I thought it was that so I tried it and ended up locking the steering wheel lol but the key still wouldn't rotate in the ignition
Old Aug 29, 2024 | 02:34 AM
Nando9000's Avatar
2006 infiniti g35x
Did you figure out what was going on with your car? Mines doing the same after removing the battery.
Old Sep 13, 2024 | 02:30 AM
GrantStewart's Avatar
mustang 1965
How is everything going now?
Old Sep 13, 2024 | 02:56 PM
jbarnett250's Avatar
You're saying the mechanical key won't turn in the ignition switch? Or just that the ignition switch won't let you turn it when you have your key fob in the car? Is your security light on the dash lit up red? Sounds like immobilizer doesn't recognize your fob and won't release the lock.
Old Sep 16, 2024 | 07:41 PM
RubenDPerez's Avatar
2006 G35 coupe
Did you ever figure out what was wrong with your car? Seems as if my car is going through the same problem. Thanks!
Juancho642
Jan 28, 2020 05:55 PM
jaguar31
Jan 10, 2015 12:54 PM
Salvadizzy
Jun 30, 2013 02:13 AM
Silencer_0
Oct 17, 2009 08:17 PM
REPPIN-NYG35
Oct 4, 2009 03:17 AM
