Radiator replacement
Guys what is the best replacement radiator for an 06 coupe? I have seen various threads and dont know what to get. I dont think I need to upgrade to mishimoto or csf as the car isnt driven like that.
Also you might want to add a whole separate trans cooler while you are in there, and just bypass the transmission cooler, but the radiator cooler actually warms the transmission in colder weather.
I used both coolers in series.
There are plenty DIY sites for this mod.
I would buy from NAPA, CPZ or Z1
If you have an automatic, I would just make sure the transmission cooler barbs are the correct diameter for your oem hoses. A lot of the aftermarket radiators have smaller barbs and it's a hassle to connect to them..imo, then finding the correct diameter barbs to mod the radiator is a bitch and a half and more $ out.
If you are manual transmission, disregard my post.
888
A Separate external Automatic Trans cooler is for warm weather places. I put mine (wife's really) in when we moved from NH to FL.
In cold climates, the oem radiator for automatic transmission coil has a built in coil with barb fittings and is a transmission fluid warmer in winter months.
It really should be thought of, or referred to as a temperature regulator imo.
Yup.
I installed this on my car 3 years ago and its my daily driver. I push it hard occasionally. Been holding up fine so far.
https://www.amazon.com/gp/aw/d/B004J...b_b_asin_title
Yes it was a direct fit. My car is a 2005 coupe automatic.
minh420
Oct 8, 2008 02:06 PM
