G35 cranks no start no codes help pls?
Old Jul 7, 2024 | 06:32 AM
Driftrocket's Avatar
Infiniti coupe base
Hey so on my 2003 g35 it was running well and then driving home from work it died . I checked the fuses, one was bad an ecu fuse and I found a coil pack was ugly like it was swollen and it gave off a misfire code for that cylinder (6). I replaced with new parts and the car cranks but won't start. I got all this replaced so far . Still no codes when scanned
new coils
New spark plugs
Fuel pump
Crankshaft
All fuses are working in every fuseboxx
my next hope is that maybe after replacing the cam sensors that will solve it
does anybody have any idea what else could it be ???
Old Jul 7, 2024 | 07:21 AM
Urbanengineer's Avatar
Any codes? Symptomatic of a bad set of cam or crank sensors.
Old Jul 7, 2024 | 07:26 AM
Infiniti coupe base
No codes besides the beginning misfire in cylinder 6. And now that's gone. We changed the crank senssor but not the cams. No effect so far. New cam sensors coming in a few days so I'm hoping that might resolve it
Old Jul 8, 2024 | 06:19 AM
Scorpi0's Avatar
Hope u are using OEM cam/crank sensors. Aftermarket sensors dont work with these cars.
Old Jul 8, 2024 | 11:27 AM
shurur's Avatar
2003 G35 Coupe
This may sound silly, but how old is your battery?
Old Jul 16, 2024 | 03:06 AM
BenjaminMitchel's Avatar
G35 Base Sedan
All good now?
Old Jul 17, 2024 | 03:01 PM
Yaboipete4's Avatar
2003 G35 Sedan AT
Crazy how I had the exact same issues I’m currently having, any solutions?
Old Jul 24, 2024 | 12:25 AM
see above for cam/crank sensor replacement recommendation. It sounds like he had this issue and a bad coil pack.
Blueytypaguy
Jun 20, 2023 11:18 AM
XxCHICKENBOOBxX
Jan 16, 2019 01:57 PM
deathdoakill
Nov 29, 2015 03:20 AM
onex_1x
Oct 26, 2012 04:00 AM
