04 g35 coupe AT Crank no start
Jul 12, 2024 | 02:04 AM
Hi I have a 04 g35 coupe that recently died while driving home last week, fuse 77 was blown for ECU had to replace that to find a code for a cylinder 6 misfire so i replaced the Ignition coil as it was damaged, wiped the code proceeded to start the car and nothing but cranking, after that I changed the following parts.
Ngk Spark plugs
Oem crankshaft sensor
oem Camshaft sensors
New battery
fuel pump
and IPDM,
Stll just a crank and no start, i checked to see if was locked out due to anti theft but that also wasn't the case. Any possible solution that can help i would greatly appreciate.Thanks
Reply 0
Jul 12, 2024 | 02:15 AM
Are u getting fuel? Are u getting spark?
Start from there.
Reply 0
Jul 12, 2024 | 02:23 AM
Yes it is getting fuel but I don't know how to check if it is getting spark
If it isn't getting spark what can be the cause of that?
Reply 0
