too high idle same ol' problem
hey, yeah there are tons of threads about this, but i tried it all, it did fix it from ~1100 to about ~800-900...
i did all the procedures to try and fix this correctly, and it did a little bit. but it won't idle normally.
is there anything i can do to try and make this thing idle correctly, what a pita... seriously...
its making it hard to shift into 1st and R because its idling too high
what can i do? i tried to unplug a few of the coils to get it to idle lower which it did, but after i plugged them back in it went right back to ~900rpm
every so often while idling it will cut down to ~650-700b like it should be, then "correct" itself back up to ~900 lol.
i did not take off the throttle body before it had this problem, but i did take it off after i tried all this crap with no luck, cleaned it all out and it still stays the same ~900rpm
tomykas
36
Apr 18, 2014 02:34 PM
alexh521
Jan 12, 2011 08:51 PM
DeputyG35
Jun 4, 2008 05:53 PM
