Anyone else think the highend is a little weak?
Old Mar 20, 2005 | 11:25 PM
  #31
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
In stock form the top end IS weak. What I mean by top end is RPM above 5K, not necessarily a 100+ MPH speed. I found that making the intake side of the engine less restrictive seems to help the top end quite a bit.
With the first dyno of my car, the engine is strong up to 5K, but from 5K RPM to 6000+ RPM it only gains 10HP. Again, the engine still makes more HP, but the slope of the curve is much flatter at that point.
Here is the last dyno I had when I was comparing a plenum to a plenum spacer. I had done plenty of polishing and porting on the intake side of the engine. The engine is still making good power above 5K. This was on a dynapack, so the absolute numbers are higher.
Old Mar 21, 2005 | 12:11 AM
  #32
akm2k5's Avatar
your probably right... Ive never seen these graphs before.. Good stuff.
Originally Posted by Finiti35
You've seen those 2 on the org right? Max hp as per Infiniti stats is @ 6,200 rpm (6,400 for 05 6MT). Not to disagree with you, but I don't see the loss of hp to be anywhere close to that of the Maxima after 5,700, or all that drastic at all. I agree with MrElussive that the VQ in the G is a high revving engine, my Maxima is nothing like it above 3.5k rpm.
Old Mar 21, 2005 | 12:50 AM
  #33
IS300TOG35's Avatar
► Matt ◄
What size spacer was tested on that dyro graph?
Old Mar 21, 2005 | 01:49 AM
  #34
E_K's Avatar
E_K
It was a 1/4" spacer. I'm also running a Crawford V5 plenum now, so there's not much space in there.
Old Mar 21, 2005 | 08:50 AM
  #35
dentalstud's Avatar
20 Year Member
So a 1/4" spacer yields about 5-7 hp MORE than a Crawford plenum? Good gravy, what would a 1/2" one do? I'm sold. Crawford plenums sound pretty much obsolete.
Old Mar 21, 2005 | 08:20 PM
  #36
akm2k5's Avatar
rwhp? Or crank hp?
Old Mar 22, 2005 | 02:20 PM
  #37
dentalstud's Avatar
20 Year Member
bump...so a 1/4" spacer has better gains than a plenum, yes or no? I can hear the 3/8" calling my name....
Old Mar 22, 2005 | 02:22 PM
  #38
CT_Texas's Avatar
Originally Posted by akm2k5
rwhp? Or crank hp?
rwhp I think.
11bEMT
May 27, 2022 03:13 PM
Thebaws11
Jul 2, 2021 11:36 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
Rehman2009
Jul 27, 2015 03:23 AM
AeroG
Jun 21, 2004 09:31 PM
