Dual??? Climate Control?
Old May 20, 2003 | 04:36 PM
GforceI's Avatar
G SQUAD
Ok If I turn one side all the way up and the other all the way down I should feel a difference in temp comming out of the vents shoudn't I? Both felt the same and I know I paid for DUAL control. Just wondering if any of you know where it might be.
Old May 21, 2003 | 12:12 AM
ReDRoK8's Avatar
Re: Dual??? Climate Control?
Did you have the A/C button on or off? that might make a differance. That's all I can think of. Also was it set to manual mode on both sides?
-Jason
Laser Red '03 6MT
Old May 21, 2003 | 12:27 AM
hoshtaylor's Avatar
I think it needs to be on auto too...not sure though
"Operator, give me the number for 911!"
- Homer Simpson
Old May 21, 2003 | 07:12 AM
MASTERSR6's Avatar
I had the same problem and called the dealership, they said with the new system it needs about 5 min to really kick in. How long did you let it go before you turned it off? My first time I tried it, after 3 min. or so I turned it off and called the dealer. They were right! It works fine. Give it some time............peace
Old May 21, 2003 | 09:29 AM
Cali_Eddie's Avatar
You need to press the Dual Climate control until you have two bar's lightened where the degree temp are. You can control left, right or dual if you keep pressing it. Just tried mine last night just in case and worked like a charm...
Old May 21, 2003 | 12:41 PM
ryoken's Avatar
They may be referring to the heater. It won't blow warm air until the engine warms up, and in auto mode it'll keep the fan at the lowest setting until the engine is warm, so that it doesn't blast you with cold air in the meantime.
Old May 22, 2003 | 08:34 AM
GforceI's Avatar
G SQUAD
Thanx guys Ill try those things and play with it a little then we'll see what happens.
Old May 22, 2003 | 03:33 PM
GforceI's Avatar
G SQUAD
LoL ok got in the car and it worked. Don't know what the problem was last time but it works fine. All's well that ends well I guess.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
BfloG35
Oct 16, 2015 05:22 PM
