Gas Left indicator on Nav?
Old Apr 4, 2005 | 03:22 PM
benbo5's Avatar
Lightbulb Gas Left indicator on Nav?
Can someone explain to me the number of miles left on the Navigation info screen. Is this number the actual miles left until the tank is empty or is there a certain amount of gas left in emergency reserve when that number hits 0. Thanks for any help, just curious.
Old Apr 4, 2005 | 03:35 PM
Derek173's Avatar
I drove for about 10 miles after the Navi said 0 miles so I could get to the "good" gas station. So its not 100%, trust me you are better off not driving the car untill it says 0 because your fuel pump will be sucking up all the dirt at the bottom of your tank.
Old Apr 4, 2005 | 04:26 PM
BBG35's Avatar
I think the NAV is REALLY inaccurate when it comes to gas mileage. I reset my mileage tracker on my tach everytime I get gas. According to my NAV I average about 19mpg, and if you do the math... 20 gallons X 19mpg=380mpg! But in reality I only get about 310 per tank before the NAV says I need more gas. And when I refuel, I have never been able to pump in more than 17 gallons. Obviously I have 3 more gallons which is 57 more miles...The odd thing is, my gas meter on my tach shows empty too! Shoudlnt the gas tach show a little more than empty?
Old Apr 4, 2005 | 05:01 PM
mrmcderm's Avatar
Both the gas gauge and the nav meter are worthless.
I just pretend that I have a 17 gallon tank, and that I average 20 mpg, and so when the trip odo says 340, time for me to fill up. My system works like a champ. I've never come close to running dry, and there is never a question about how far I can go before I have to refill.
I've never put more than 19 gallons in, and sometimes my gas light comes on before 340 miles, and sometimes it doesn't, but I usually put 17 - 17.5 gallons in.
I haven't trusted fuel gauges since I once ran a wing tank dry on a solo cross country when I was learning to fly. Every one of my cars has had the same ridiculously inaccurate fuel gauges.
Old Apr 4, 2005 | 05:07 PM
benbo5's Avatar
Now I am definitely confused. Im the type of person that does not do the math at all so I just look at the needle. Why am I looking at that number anyways so dumb. I should know that it is not accurate. Thats not bad at all getting 300 mi. on a tank.
Old Apr 4, 2005 | 07:31 PM
Potty_Pants's Avatar
Cant answer for a fact. however when my Navi was close to 0 miles I performed a fill up and it had exactly 2 gallons hiding. imo its a safety precaution .
now as far as the readings from the navi. they have been DEAD ON ***** ACCURATE. how did i come to that conclusion... filled the tank to the top , exhausted a majority of the gas then refilled. devided miles driven vs gallons added and the number was spot on.
I have no idea whats happening with some of the other members , perhaps they have the gas tank problems mentioned in other threads ?
gl
ppp
Old Apr 4, 2005 | 08:19 PM
Sickone's Avatar
man guys....
Tank is 20 gal (from bone dry - don't go there)
My Nav is dead nuts everytime, the meter in the tach is a little iffy through the range.
Let me see if I can explain...
The Nav tells you your average MPG (if it says you got 19MPG and you put in 17 Gals to fill it then you should have traveled 323 miles.... duh)
The miles left is much more dynamic. It should tell you '0' right at 2 gals left (18 gals used) where the meter in tach will say empty and turn on the 'need gas pumpo icon anywhere between 2 and 3 gallsons left.
The Miles left display on the nav is much more dynamic as you get lower and lower., and based on mostr recent driving. Let me see if I can offer an example.
You have been crusing along at a perfect 20 MPG for 300 miles (you have used 15 gals) thye Miles left will show 60 miles (3 more gals at 20 MPG.... leaving the 2 gallon reserve)
BUT....... if at the same 300 miles after a perfect 20 MPG, you stuff it in the floor so you are getting 5 MPG and hold it there the Miles left will rapidly approach showing much less miles left like 15 or 20(3 gals at 5 mpg) if you ease up and cruise again it will start to climb again.
It is telling based on a much shorter integration period the estimated use left.
Old Apr 4, 2005 | 09:12 PM
Beowulf's Avatar
The "miles left" meters in general are always calibrated to give you some buffer. You could probably go more than 50 miles on "0 miles left" until you go dry. All it is a calculator on your mpg. They intentionally calibrate it this way because there is always people who push it and they don't want someone run out of gas because of a slight miss calibration.
Old Apr 4, 2005 | 10:50 PM
my god you know how many people in the US would SUE if their car said they had 5 miles left and they ran out of gas. *sigh* state of the world i guess
ppp
Old Apr 4, 2005 | 11:40 PM
EffEcks's Avatar
ppp
Yup, that's why I'm surprised the the thing even counts down to zero - on our FX (which is an '03) the display switches over to a couple of asterisks when it gets down below about 10 or 15 miles. Either they have more confidence in the new system or they've just added in a cushion so they don't have to sweat it.
Old Apr 5, 2005 | 12:37 AM
Sickone's Avatar
the G35 goes to asterisks also, but it does that (0 left to asterisks) with 2 gals left in tank. I.e. they say you are empty when you still have 10% of your tank.
magnetism80
Feb 1, 2019 10:00 AM
lil beezy
Lights
Nov 16, 2015 02:52 AM
NJ6MT
Sep 10, 2015 08:40 AM
Rhinos7777
Sep 6, 2015 05:36 PM
