does your car roll forward a little after u parked(5AT owners)
Originally Posted by avs007
I have an 04 coupe. I do use the e-brake, but it still does that in my garage once in a while. (And the tranny never clunks when I go to leave)
Yeah, my '03.5 auto does this too. I think it's because the weak parking brakes we have. You really have to press it down really good. Lately, I've been shifting into Neutral, set parking brake, let it roll a bit, then shift to Park(no clunking later when I go from Park->Drive). Hopefully this will save my auto trans a bit.
When you put your auto in park, all you're doing is locking the output shaft by putting it against a fixed gear or arm, one that does not rotate. When you're parked at an incline, the weight of the vehicle puts some pressure between the shaft and the fixed gear. Then when you come out of park, you pull the fixed gear away, but since there's pressure between them, when they give it clunks.
Originally Posted by benbo5
mine rolls about an inch also even when I push in the emergency brake, I wish we had one you lift up on next to our shifter, but what can you do. Wonder if its hurting the brakes when it rolls a little after parking?
THe problem si if you use this (putting the car in park) as your sole means of keeping the car form moving - the constant stress can cause the pin to break (or whatever component the pin is designed to engage to break) - and you are looking at an expensive repair.
Always engage your ebrake before putting the car in park! if your car rolls at ALL after engaging your parking break - you should have your parking break checked.
Check this out for a great explanation: "When I put my car in park, what really keeps it from moving?"
Tolboothwilley™
Exterior-Vendor
07-28-2016 12:42 AM
johnjohn077
Audio/Video/Electronics
08-05-2015 03:09 AM
Bean_VQ35DE
49
08-03-2015 05:17 PM
