service engine light
Old Apr 24, 2005 | 11:17 AM
InG35CopNaV's Avatar
i have OCD with my car, i change the oil at 1000 miles and every 3000 after that and i change the tranny fluid ever 5 thousand miles along with the plugs and air filter now i know that this is a waste of monay but you know what i love my car... my question is that the service engine light is on and i dont know what to do to get ride of it...
Old Apr 24, 2005 | 01:15 PM
damnz2z's Avatar
There are numerous ways to get rid of the SES light. You can do an ECU reset. The easiest way is to remove the negative terminal from the battery for at least 10 hours or so. There are more ways by checking out the sticky in the Technical and Modifications forum. If that doesn't work, you may need to find a place or someone with an ODBII scanner and reader to figure out what is the problem. Hope that helps!!
Old Apr 24, 2005 | 01:16 PM
mc2's Avatar
mc2
you could probably just bring it to the dealer.
there's a reason that light is on and i'm sure they would pull the codes for you. especially if you are still under warranty.
Old Apr 24, 2005 | 04:38 PM
dave's Avatar
Try tightening the gas cap.
Seriously, that is one thing that will make the light come on.
If that's not it, get someone to read the codes and tell you what is wrong. Some auto parts stores will read the codes for you for free. Otherwise take it to the dealer.
Old Apr 24, 2005 | 04:44 PM
GeeWillikers's Avatar
Walking The Fine Line...
Auto Zone scans for free. Could be a million things.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Ednica87
Sep 5, 2015 02:59 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
