Smell when shifting at high rpm
Old Apr 30, 2005 | 01:11 AM
Lokoto's Avatar
Ever since I bought the car, I get a burning type of smell when shifting at 5-5.5K. I wrote about it last year and most people said it is the paint and it just has to burn out. Well, 13 months later and 10.000 miles, it is still the same thing. Should I worry about it? The dealer has not been helpful at all.
Old Apr 30, 2005 | 01:41 AM
Gee Im Fast's Avatar
No I think its normal when a car has been run at high rpms...but I usually get that smell when rippin on my car at high rpms...higher than what you said. But if I were you, I wouldn't make that rpm range your constant shifitng rpm (I doubt you do this anyways)....but most cars that the driver works the engine good, end up with what I call: "been hard workin" scent to em, usually it's the clutch.
I'd be worried if you smell that after shifiting at 3krpm on a normal drive.
Old Apr 30, 2005 | 02:49 AM
mc2's Avatar
mc2
what type of burning smell is it?
burning clutch? or burning oil? or burning coolant?
could you describe the smell?
I'm imagine you know what burning clutch smells like right?
Old Apr 30, 2005 | 04:23 AM
EricIsKlumzyee's Avatar
what if 4-5k was your normal shifting point?
btw u get around 15miles per-gallon
Old Apr 30, 2005 | 09:29 AM
Msedanman's Avatar
O.F. Administrator
When you shift at that rpm, do you power shift or rev match to avoid slippage?
After this length of time, it has to be clutch or some fluid leakage under the hood.
Look for puddles or other clues.
C.
Old Apr 30, 2005 | 11:01 AM
Lokoto's Avatar
At that range I mostly power shift but the smell that comes out is more like the smell of burning coolant or oil. I also sensed the smell coming out from the tires after they get warm and was wondering if that could be the case.
I don't normally shift at 5K or so but every time I get up there for a spiritted driving, you get the smell which has just concerned it. All your suggestions are right on the money as usual.
Old Apr 30, 2005 | 11:32 AM
mc2's Avatar
mc2
well burning coolant smells much different than burning oil.. burning oil will have almost a rubbery smell... but burning coolant smells very sweet.. an almost "delicious" smell.
twentyeggs
Sep 11, 2015 03:58 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Rhinos7777
Sep 6, 2015 05:36 PM
G35CO
Sep 4, 2015 09:27 AM
