brake/hydraulic "squeal"
Old Jun 2, 2003 | 06:20 PM
jeffjcalweb's Avatar
quick question... i've had a consistent brake squeal since mile 0. the consistent part is, it only happens after the brakes are hot and its at a very slow stop, like i've engine braked or coasted and put the brakes on to just stop rolling... i mentioned it to the service advisor a while back but was told to give it a couple of weeks. well, still there... was wondering if anyone else noticed this? 6mt w/18" & brembo's.
Old Jun 2, 2003 | 06:31 PM
rstark's Avatar
Re: brake/hydraulic "squeal"
Yep, I have the same problem. Infiniti service is going to replace the pads with "another type" for the Brembo's. Still waiting for the parts to come in.
-Rick
Old Jun 2, 2003 | 07:32 PM
ReDRoK8's Avatar
Same problem here. I am taking it in to get looked at this week. I'll let you know what they say. Peace.
-Jason
Laser Red '03 6MT
Old Jun 2, 2003 | 08:52 PM
derek's Avatar
From: Metropolitan South Farmington, not too far from the supercity we all know as Wilmot, NS
Not just the brembos, folks- same for me w/ 5AT & performance package- heard till they cooled off tonite. Pad material doesn't like the heat.
DB
Old Jun 2, 2003 | 09:01 PM
Meatshackle's Avatar
Deep Sea Moderator
Yeah it sucks when you're rolling up to a traffic light, security gate, drive thru window, or any and every other time people have a real good chance to look at your car and the dam brakes squeal.
Russ
Black w/willow, 6MT, premium, nav, & aero
Old Jun 2, 2003 | 09:27 PM
GraphiteG35's Avatar
I had and still have the exact same problem. I posted a similar question/concern awhile back, and received almost a unanimous response that this is occurring to everyone. You can check out the reponse to my question by sorting at the subject line and look for the posting "Brembo Brakes Squeek". I have 1400 miles and they still squeek occasionally. They did get a little better.
According to the service manager, every single G35 has this problem, because Infiniti decided to use very hard pads for G35 to have impressive braking distance. He said the feedback he received from Infiniti was that you can get a softer pad, but will wear the pads out in 5,000 miles (this can get costly)
Hope this helps.
Old Jun 2, 2003 | 09:59 PM
freeagenttd20's Avatar
I had the exact same problem, and infiniti is going to replace the rotors because they are warped. Im taking the car in tommorow, so ill let u know what happens
Old Jun 2, 2003 | 10:13 PM
COUPEDIT03's Avatar
Yes...this subject has been addressed over and over...its gravy though..one more time wont hurt..
Yes I had the problem too....It went away after a while..i forget when but I havent heard it in a while..im at something like 5650 miles now..around there..dont know exactly..dont ever look at my odo..or speedo for that matter...just hear the engine purr and shift....It'll go away after a while..
"Dont start none, won't be none"
Old Jun 3, 2003 | 12:17 AM
thanks all. i must not have searched hard enough before posting. i appreciate the feedback... and i guess no look is a bad look, even if they look cuz the breaks squeeked!
especiallly if "they" look like rumble's girl in his sig.... later!
Old Jun 3, 2003 | 11:10 PM
MontrealCoupe's Avatar
I'm getting mine fixed for that problem and the cd problem june 11th.
Thoes are the 2 problems that alot of G35 had...I hope the next one won't be the tranny.
Old Jun 4, 2003 | 08:18 AM
tonke73's Avatar
My G coupe had the same problem. It stops after a couple of thousand miles. Try bedding the brakes. go to http://www.baer.com/Support/TechTips.aspx?TechTipID=5
3000vr4tt
Sep 7, 2015 12:48 AM
G35CO
Aug 25, 2015 02:00 PM
unomateo
Forced Induction
Nov 22, 2005 05:18 PM
live2ski
Nov 8, 2004 08:19 AM
rmeaux
Sep 26, 2003 05:54 PM
