350z H.Tech Before & After (PICS)***
Old May 13, 2005 | 06:01 PM
G Thizzle's Avatar
Talking 350z H.Tech Before & After (PICS)***
Here is my coupe with 350z Tein H.Tech Springs. These pics are 1 day after install.... perfect drop...just hope i can get back within specs....
Before
After
Before
After
Before on a stock coupe @ work
After
Old May 13, 2005 | 06:03 PM
TwoK4drSi's Avatar
Looks good. I have the same springs
Old May 13, 2005 | 06:16 PM
EricIsKlumzyee's Avatar
bigger diff than i thought. nice choice
Old May 13, 2005 | 07:41 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Looking good!
Old May 13, 2005 | 07:45 PM
IS300TOG35's Avatar
► Matt ◄
yup the drop is perfect, I got em to. Your rear might be out slightly. I know they couldnt get my left rear camber back in and ended up setting them both to -2.08 which isnt to bad. I might invest in some kintetix camber arms to fix it but everything else is went back to spec.
Here is some some comparision Pics if anyone is trying to decide on springs. My G (DG) is on 350Z H-Techs, and the Black G is on G35 S-Techs.
Old May 13, 2005 | 07:52 PM
AustNMike's Avatar
looks nice...good choice...so what's the diff between the Z H techs and the G H techs?
Old May 13, 2005 | 08:00 PM
IS300TOG35's Avatar
► Matt ◄
Z H-techs on the G are a .8 front .7 rear and the g s-techs are i think 1.3 front 1.2 rear or something very close to that, somone correct me if im wrong on the s-techs measurements.
Old May 13, 2005 | 08:08 PM
AustNMike's Avatar
I'm looking for the diff between H-techs for Z and G....I know the S-techs are more of a drop....are the G H-techs less drop than the Z H-techs? thanks for the input!
Old May 13, 2005 | 08:16 PM
kenchan's Avatar
definitely looks better lowered.
Old May 13, 2005 | 09:33 PM
daniel3ooo's Avatar
looks awesome...did you get any shocks to go with those springs?
Old May 13, 2005 | 09:47 PM
G Thizzle's Avatar
thanks for the comps.... nah i still got stock struts.... it rides real good.... the Z H-techs on a G are about a .7F and .6R drop... the G H-techs are only about .4F and .3R.... The Z h-techs sit lower.... how long do you think i should wait before i get my alignment????????????
Old May 13, 2005 | 10:40 PM
skeleton_cru's Avatar
Sedan
Thumbs up
99, great job with the before and after pics. It really gives you a good idea of what to expect with those springs. BTW, your coupe is coming along nicely. Keep up the good work.
Old May 13, 2005 | 10:57 PM
G Thizzle's Avatar
Thanks alot Skel..... i should be getting my rims on Tuesday... I will post pics then.... next project will be the DD with the Eclipse AVN.....
AustNMike's Avatar
thanks for the info on the springs....I would align it as soon as possible, but you probably have at least a few hundred miles before tires wear too bad....is it pulling or anything?
Old May 13, 2005 | 11:17 PM
TheGest's Avatar
Gangster Member
Why the 350z H Tech, what is the differance
