Stock 05 vs stock 04 races
Old May 27, 2005 | 10:00 PM
  #46
MaDdFLaSheR's Avatar
Originally Posted by Gee Im Fast
Settle down Mike I am experienced, but was still uneasy takin my car that far up so I never really tried at the time (at 60mph rolls I think you were droppin to 3rd, I only dropped to 4th each time ). However...
However, when we did run from a stand still, we both took off the same time, and we both were DEAD EVEN!!! It was picture perfect, no one gained on the other...so when it all comes down to it, they ARE THE SAME PEOPLE!!!!!
I have had my car since January...only 2500 miles...so I dont like to beat on it.
thats exactly what i said man.. the cars should run nearly exactly the same.. its always either a driver's race or based on other outside factors.. quote:
"even after that i still think the cars basically perform exactly the same and some other factor must have made up for my lead in those races.."
hahahahaah and dont even try to lie about that 4th gear thing.. we were on the phone and i made sure you were in 3rd also... i believe your exact words at the time were "damn, i guess your car is just faster" ahahahahahah
ay jimmy lets go to the track some time for the hell of it.. your car will appreciate a day of beating.. gimme a call if you're in LA this weekend if you wanna kick it.. i wanna show u my overlays and tint
Old May 28, 2005 | 11:49 AM
  #47
ChazM's Avatar
Originally Posted by 636Racer
In an exagerated form, I'm willing to bet my old t-type before mods would better you in 60'. black and white says my old 86 t-type made 245hp/355tq. I'll guaranty you my 60' times would be better. tq is what gets you moving, hp is what keeps you going. where I'd beat you in torque, you'll catch up with horsepower. you have much to learn padwan.
suffice to say, GN/T-Types did 0-60mph in less than 5sec. I dont think the 04/05 G35 can touch that.
Ok, you car had how many more pounds of torque? I'm saying that 10 less lb/ft of torque is not going to make a difference in 60ft time.........you have much to learn padwan
Old May 31, 2005 | 03:20 PM
  #48
636Racer's Avatar
so you agree then? that there is a difference, even if there isnt that much.
Ryan-----------------Me
R/T .249 -----------.617
60' 2.159-----------2.239
330 6.140-----------6.210
1/8 9.364----------9.418
MPH 76.91----------76.94 (catching up a tad)
1000 12.112---------12.145
1/4 14.430---------14.446
MPH 96.02----------97.83
you obviously chose the right example to what I'm getting at.
Not much of a difference, but a difference none-the-less.
Old May 31, 2005 | 05:43 PM
  #49
DaveB's Avatar
ChazM, thanks for the comparison race. BTW, what were the average 1/4 MPHs between your car and Ryan's. I see that you're going 1.8mph faster in your comparision run, but sometimes these VQs aren't the most consistent cars when it comes to trap speed.
10 ft/lbs isn't going to make a difference. My 96 Maxima did low 2.2 60 foots with 170whp/180wtq and 205whp/200wtq. The difference in acceleration was markedly improved from 330' on.
Originally Posted by wnt1bd
1 other thing the SLOWEST my car has run with an Intake was 14.5xx with VDC ON. I have over 25 race slips to prove all my numbers.
I want to see your "best" slip, increment by increment. Unless I see something better than a 13.9@101mph, you're not going to make a believer out of me that the 298hp motor is quicker and faster in the 1/4 mile.
Originally Posted by G35 TX
Probably in the 1/4 they are equal, but if it was a mile race or more, the 05 might pull away due to better high end power.
Just a thought.
Exactly. The softer midrange power of the 05 6MT will make it marginally slower to 70mph than the 280hp motor and then as speeds increase and the gearing gets longer, the 05 will be able to take advantage of it's better topend power which is situated in the last 1000rpms of the rpm range. Above 100mph, the 05 should slowly be pulling away.
Old May 31, 2005 | 07:39 PM
  #50
G35_TX's Avatar
You know what this sounds like Dave? Past memories...4th gen vs 5th gen 2000-2001 .
Old May 31, 2005 | 09:12 PM
  #51
636Racer's Avatar
comparing apples to oranges. The 3rd Gen Maximas were quick in their time, I had a 95 SE. It was hard to find a car that actually pegged it's speedometer like how the Maxima did.
But this is in regards of the example that ChazM, it clearly shows that the 04 is quicker to ChazM's 05.
Old May 31, 2005 | 10:34 PM
  #52
ChazM's Avatar
^you are not understanding me...that was only one run, sometimes I beat him through the 1/4 mile in ET and my trap would be slower!
Old May 31, 2005 | 10:36 PM
  #53
perfectmax's Avatar
My buddy at work has an 04 coupe and I have an 05. We race once in awhile and he has yet to beat me.
Old May 31, 2005 | 10:44 PM
  #54
636Racer's Avatar
I understand that.
But I was explaining to you in theory what torque and horsepower is and their effects. reason why I gave you an exagerated view on how my old car performed, to show an exagerated difference to your small difference you're trying to show.
so if you'd lose as well, what was your friend's times at which you lost?
Old May 31, 2005 | 11:00 PM
  #55
wnt1bd's Avatar
Ok, you asked for numbers...here ya go. These are the top 10 1/4 mile times I have out of 26.
Best will be first of course. i'll give you as much as I can.
Time: 1# 14.063 2# 14.121 3# 14.123 4# 14.132 5# 14.177 6# 14.193 7# 14.217 8# 14.229 9# 14.234 10# 14.257
60': 1# 2.129 2# 2.208 3# 2.184 4# 2.121 5# 2.163 6# 2.181 7# 2.123 8# 2.144 9# 2.183 10# 2.219
MPH: 1# 101.10 2# 101.49 3# 99.85 4# 99.19 5# 100.14 6# 99.00 7# 98.98 8# 99.85 9# 99.03 10# 98.90
I also have 330 times, 1/8 times and speeds, 1000ft times. Not sure if you need all that as well, but just post and I will. I do not wish to continue this great debate, but I still contend that if you have equal drivers the 05 will win. What people I don't think are relizing is that .1-.5 is anywhere from half a car to almost a car and a half distance in a race, and that is just at the first 1/4 mile. If this race were to continue to a mile or more the distance would be even greater. i am not trying to be a ***** or anything just speaking from my personal expirence at the track and on the streets.
Old May 31, 2005 | 11:08 PM
  #56
636Racer's Avatar
I was looking for 04 numbers, not 05s.
I wasnt debating about who'd win either.
I was explaining the outcome of different powers. HP vs TQ.
Old Jun 1, 2005 | 12:16 AM
  #57
DaveB's Avatar
Your times and trapspeeds seem to go hand in hand with what the 03/04s are getting. Capital is a quick track and I'm a bit surprised you're not quicker. I've seen some wicked stock times from 03/04 350Z 6MT and 5ATs at Capital over at MY350Z.com. We're talking 13.6-13.8@102mph stock.
Old Jun 1, 2005 | 02:37 AM
  #58
ChazM's Avatar
I understand that.
Here's an example where I beat him on ET, with a better 60' time but ended up with a slower trap.
I understand that torque will get you off the line better, but what I am trying to explain is that I have about 7 less lbs of torque and about 10 more hp (we both dyno'd together) and just because I showed our best run that night and it just so happened that he had a better 60' and I had a better trap, but that doesn't prove anything.
----Me---------------------------Ryan
R/T--.480-------------------------.071
60'---2.237------------------------2.266
330---6.229------------------------6.256
1/8----9.447------------------------9.508
mph---76.64------------------------76.75
1000---12.185---------------------12.267
1/4----14.492----------------------14.589
MPH---96.49------------------------96.60
Old Jun 1, 2005 | 03:49 AM
  #59
98intrigue's Avatar
My trap speeds are always 96.xxmph. Never have I once gotten higher. My car seems to trap a lot slower than most G's.
And just to let people know, the track Chaz and I raced at is known as "Orlando Spin World"...meaning that we could likely have better times at a better track.
Old Jun 1, 2005 | 10:08 AM
  #60
da45king's Avatar
Originally Posted by Klubbheads
How high can you rev 05s? I know its 7000 redline but does it go above that without hitting the rev limiter? Because every 03-04 I drove revs to 6900 rpms without hitting the rev limiter.
Damn I thought I was the only one who....had it like that
