Squeaky clutch pedal!!!
Old Jun 13, 2005 | 09:01 PM
COMBUSTION's Avatar
WTF!!! Does anybody have a squeaky clutch pedal? I brought it to the dealer and sprayed some lube on it but could not fix the squeak... This is embarrassing when you have a chick in the car... every time you press on the clutch pedal and depress it squeaks. HELP!!!
Old Jun 13, 2005 | 09:14 PM
peet's Avatar
U sure it's the pedal? There is a weird whistle like squeel sound (fairly soft) that occurs when taking away engine power at 3000-3700 RPM. To replicate, get it in gear, go fast enough to be 3300 rpm, take foot of gas. Listen.
Same sound? If so - not the pedal then.
cheers.
Old Jun 13, 2005 | 09:27 PM
kenchan's Avatar
pedal or one of the cylinders? or the fork?
Old Jun 13, 2005 | 09:30 PM
G352NV's Avatar
Never enough
Its down near the tranny. My car does this also. My OLD civic did the same.
Old Jun 13, 2005 | 11:29 PM
Hooman6MT's Avatar
20 Year Member
my car did the same thing, took it in and they said it was normal. According the service tech, the 6mt are very loud.
Hooman
Old Jun 14, 2005 | 01:18 AM
kenchan's Avatar
mine doesn't squeek.
Old Jun 14, 2005 | 05:17 PM
MikeStarrG35's Avatar
Obsessive Owner
mine doesn't squeek, but it is pretty loud. Depressing clutch between 3k and 4k rpms leaves a howling noise, sounds like something that was spinning and is slowing down, lasts for about 1 second after i depress clutch.
Old Jun 14, 2005 | 05:29 PM
TheGest's Avatar
Gangster Member
cheers.
ya the O5's do that, i hate that sound
Old Jun 14, 2005 | 05:30 PM
TheGest's Avatar
Gangster Member
My 05 does that, i took to the dealer, they told me its normal i wanted a new car, 03-04 dont do that i believe
Old Jun 14, 2005 | 05:57 PM
peet's Avatar
That sound is making me nuts. What is it anyhow? Dealer service advisor said it had something to do with a two position clutch. Sounds fishy. Anyone have any hard notes on what it is?
P
Old Jun 14, 2005 | 06:05 PM
g6g35's Avatar
I have an 03 and my clutch squeaks like a bitch, it also just started to make some kind of thump before hitting 2 rpm when in 1st gear.
Old Jun 14, 2005 | 06:23 PM
dgbos4's Avatar
My 03 squeaks bad - it is embarassing when stopped at a light.
I also have a clicking noise from the rear that is driving me crazy. I asked them to tighten the rear axle bolt but that didn't work.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
jbmw002
Sep 10, 2015 12:54 AM
TheBay
Sep 3, 2015 03:27 PM
