Why does it sound like it's struggling?
Old Jun 24, 2005 | 09:46 AM
KAHBOOM's Avatar
yeah reset the ecu and it will feel like it can't get enough.
Old May 25, 2017 | 03:48 PM
ABakedFish's Avatar
Having the same issue
I've recently been experiencing the same issue with feeling like the car begins to struggle around 5k. I have had the car for 4 years and have notice a significant change in power over the past month or two. My g is completely stock, occasionally when driving my vdc light or my engine service soon light will go on but turn off either while driving or when I start the car back up. I drive the car pretty aggressively so it should be used to using a good amount of power.
considered changing my camshaft position sensors, spark plugs, and using seafoam to clean the engine or manually clean the throttle body(which i'm trying to avoid). My G has 95k miles.
haven't done anything yet though, any advice would be nice.
Old May 25, 2017 | 05:22 PM
RyanY's Avatar
Cam position sensors don't wear out, they're either working or they're not. If they weren't working you'd have a Service Engine light on and codes stored.
Get the maintenance up to date - spark plug & air filter condition will affect how it runs.
Since you said you've seen the SES light some on, have you checked for stored codes?
Old May 25, 2017 | 08:48 PM
ABakedFish's Avatar
Haven't checked codes yet there are no lights that are continuously on but plan on doing that this weekend before I purchase any parts. I also think its the spark plug and air filter which was my initial guess but as I continued to search I found more information that also sounded like it could relate.
another strange symptom is stuttering on some start-ups.
Thanks again.
Old May 25, 2017 | 08:49 PM
Urbanengineer's Avatar
Catalytic converters have been known to clog up and inhibit performance too. There are quite a few options.
Old May 25, 2017 | 08:53 PM
ABakedFish's Avatar
When looking for problems with the catalytic converter would it throw off a specific code I should look for when I scan it this weekend? Or is there a way I can visually see if thats what affecting my performance.
Thanks.
Old May 26, 2017 | 02:59 AM
It would specifically feel like it has no umph from 4K to redline - because flow is restricted out of the engine.
Old May 26, 2017 | 11:05 AM
RyanY's Avatar
Thanks.
It probably won't set a code for a clogged converter, unless the converter is not actually functioning, in which case the O2 sensors would tell the ECU that there's a problem.
The only way to check the converter without removing it would be to drill small holes before and after the converter and connect a pressure gauge to determine if there's a significant obstruction causing higher pressure before the converter. It's more time consuming to remove the converters and do a visual check but at least you aren't drilling holes in your exhaust.
There's a product called Cataclean that I've heard a few good reports about, although I have no personal experience with it. It won't help if the converter substrate has melted due to an overly rich mixture, but if the problem is just due to deposits on the converter substrate itself it could help.
Old May 27, 2017 | 12:06 AM
ABakedFish's Avatar
Sounds great probably gonna do the regular maintenance first such as spark plugs and air filter, I know it's early but the way I drive it may be the problem I've also had the car since 52K so I know it hasn't been done before. If that doesn't solve the issue gonna look into the converter next.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
