help injen intake
Old 06-24-2003 | 06:51 PM
taikien's Avatar
help injen intake
i just install injen intake on g35 coupe.drove it around neighberhood but engine light is still on.engine light was never on before i install intake.was wondering if anyone had this problem.
Old 06-24-2003 | 06:57 PM
Msedanman's Avatar
O.F. Administrator
Re: help injen intake
Did you reconnect the Mass Air Flow sensor harness?
<font color=green>GSM</font color=green>
Old 06-24-2003 | 07:04 PM
taikien's Avatar
yes and the little hose
Old 06-24-2003 | 07:16 PM
ReDRoK8's Avatar
Disconnect the battery and then go back and recheck that you reconnected everything properly, Mass Air sensor etc. Then let the car sit for maybe 20 minutes and then reconnect the battery and see if the error light is gone. Point: If you disconnect the battery long enough it should reset the ECU. Also you may actually get a little more performance from your intake after the reset. That is until the ECU starts retarding timing and changing the fuel to air ratio in order to get the factory settings back. Good Luck.
-Jason
Laser Red '03 6MT
Old 06-24-2003 | 08:51 PM
taikien's Avatar
i disconnected battery cables and will let it sit over night.i hope it will work
Old 06-25-2003 | 12:19 AM
taikien's Avatar
yeap that did it.the intake is worth it.thanks guys
05-22-2022 09:26 AM
Picture Share
02-04-2018 12:41 PM
Video Share
01-31-2017 04:00 PM
andrewvk
Engine - Complete Motors
32
04-07-2016 01:39 PM
vamarris
09-26-2015 12:56 PM
Quick Reply: help injen intake
