road feel difference between 40mph & 80+mph on 19" wheels
Old Aug 19, 2005 | 01:33 PM
kcaja@go.com's Avatar
i recently upgraded my stock 17" wheels & tires on my spanking new 05 lakeshore slate to 19" inchers aftermarket wheels with 245/35/19 dunlop direzza on all four corners. i can definitely say 17" are a lot smoother on all speed but the new 19"s handle corners a lot better.
my question to anybody who has 19"s on their Gs is, do you feel substantial road feel difference with speeds of 40mph and 80+mph in terms of smoothness? the reason i'm asking is i'm a little bit leery about my new wheel balance. i feel a very minor vibration on my steering wheel at 80+mph but i can't really discern if it is really the road feel due to lower profile tires or my wheels need more balancing.
Old Aug 19, 2005 | 01:50 PM
FAST1's Avatar
Properly balanced 19" wheels should not vibrate at speed.
Old Aug 19, 2005 | 01:58 PM
whyjay91's Avatar
I get zero vibration on my stock 19s and potenzas either at 30 or 152.
Old Aug 19, 2005 | 01:59 PM
kenchan's Avatar
get it rebalanced on a hunter roadforce balancer. it should not vibrate at all.
Old Aug 19, 2005 | 02:12 PM
Deang35c6's Avatar
Is it a constant vibration? There's a section on the I90 that causes my steering wheel to vibrate. My wheels and tires are balanced and the vibration only occurs on this section of the road. You will feel more of the road due to the loss of side wall. Also keep in mind that trameling (sp) becomes more pronounced when you widen your tires, increase spring rates, or dampener rates. On some streets, I dare let go of my steering wheel for fear of going into another lane. This isn't necessarily a bad thing. It means my suspension mods are making sure the front and rear tires are staying planted, albeit following every groove in the road.
Old Aug 19, 2005 | 02:18 PM
Orlando333's Avatar
run on 19s with no vibration up to 120
Old Aug 19, 2005 | 02:22 PM
badtziscool's Avatar
No vibration here, but you will get some road surface feedback through the steering wheel, if that's what you're feeling. If it shakes back and forth then it probably an imbalance. If it's a vibration like, well, a vibrator but not as severe, then it's just the car talking back with you.
Old Aug 19, 2005 | 02:31 PM
jimcambell's Avatar
Completely smooth up to 115 (so far) here......
Old Aug 19, 2005 | 02:38 PM
the hunter balancer costs $100+ in my neck of the woods. however, since i'm not fully satisfied with the current situation, i 'll just go back to whoever mounted my tires and let them re-balance it and if they can't balance them to my satisfaction then i'll request a refund and head to a hunter balancer. thx for all the inputs...
Old Aug 19, 2005 | 02:48 PM
Chico's Avatar
That's a good idea, but you should also check your tire pressure. Shops usually overinflate them.
BTW, I have 20's and no vibration at all.
Old Aug 19, 2005 | 03:02 PM
6th bolt on front axle
i also had an issue putting my new wheels on the front axles. i had to take off the '6th' bolt. do you have any idea what's the sixth bolt for? since i took them off, are they possibly causing the very slight vibration on my steering wheel?
Old Aug 19, 2005 | 10:54 PM
Andy2434's Avatar
Just good vibes here.
Old Aug 19, 2005 | 11:05 PM
reggiek's Avatar
Usually, it's under inflation that can cause vibration. Either way, check the tire pressure.
I can't believe someone would own a near 40k car and think $100 is too much to get a proper ride. If that's what it takes then that's what it takes. Don't be cheap. I'm not saying to throw away money but I can't understand a Civic attitude from a G35 owner.
Old Aug 20, 2005 | 01:46 AM
heeb's Avatar
Check your tire pressure.
$100 shouldn't be a bad price for demanded perfection when it comes to something as important as wheels and tires.
But it shouldn't even cost you that.. Go to an STS near you or something. I got mine balanced there with their Hunter machine and it only cost me 52 bucks.
Old Aug 20, 2005 | 02:21 AM
mwarsh1's Avatar
You Might Need Hubcentric Rings?
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
