Easiest way to claybar
Old Aug 24, 2005 | 11:30 PM
izmir41500's Avatar
G35driver Addict
just got to tough it out. clay is clay, so any bar will do, but i don't trust the really realy cheap ones, go with brand name. they're $9.99 at autozone. be sure you're using a lubricant. either detailing spray or water/shampoo mixture. the bar should glide across your paint. if not you need more lube.
Old Aug 24, 2005 | 11:42 PM
RX_Renesis's Avatar
how about trying to put 2 bars together thus bigger surface area... 6inch area to work with...
Old Aug 24, 2005 | 11:57 PM
ZeroGen's Avatar
Omega Enthusiast
Buy your buddy a 12 pack of Sam Adams Boston Lager to help you out....
Old Aug 25, 2005 | 12:09 AM
94gxe's Avatar
If you have a DA buffer like the Porter Cable you can get a foam pad holder from Griot's Garage that holds a clay bar. Thoroughly wet the foam pad and the paint surface and then use the buffer just like you would to polish or wax. Works great
Old Aug 25, 2005 | 12:17 AM
myGspot's Avatar
I would not suggest using the porter cable for claybar.
Claybaring is a process in its own. Takes time and effort but the results are worth it. I do it 3-4 times a year. Followed by a good wax such as carnuba. I also try to polish/wax the car in between to keep the paint protected.
You just gotta be a man and do what you must. I use mother claybar and lubricant. Works just as great as zaino. My friend uses zaino and i just dont see what the big deal is about. My car looks just as polish and just as good.
Porter cable buffer is only good to apply glaze/polish/wax i always take it off by hand.
Old Aug 25, 2005 | 12:37 AM
2slo2bfurious's Avatar
+1 cuz Porter cable + claybar = losing paint
Old Aug 25, 2005 | 01:05 AM
AVJunkie's Avatar
Just do it by hand. It really doesn't take that long unless if you've got a lot of crap in your paint. Don't waste the Zaino Z6 though by using it as lube, use Z7 + water and use lots of it. Also, you only need to use half of one of the Zaino claybars at a time.
Old Aug 25, 2005 | 01:26 AM
G35Vision's Avatar
1. You can't clay a car with a machine ... If you can .. I never heard or saw it done ..... & I detail cars on the side .. I would never
2. Clay is not clay... there is different textures/coarse types of clay
3. When done right it should only take you 15 to 20 minutes
4. 1 bar should last for 3-5 cars depending on the condition of the car
Old Aug 25, 2005 | 01:40 AM
G35Vision's Avatar
Just spray the lube mixture of your choice in a 3'x3' section and glide the clay over the area .. you should not be rubbing the clay like a mad man ... on a car in your condition it will take no time ... you don't have to take for-eva with the clay .. just work each section 1 minute at a time ..15 minutes ... done
Old Aug 25, 2005 | 02:19 AM
G35Vision's Avatar
OMG I just found a picture of it ...... LOL The world has gone crazy
Old Aug 25, 2005 | 02:23 AM
sen_jen's Avatar
Meatshake Enterprise
use a spray wax when claying.
