MAF Sensor CLEANING
Old Oct 1, 2005 | 01:25 AM
Derek S's Avatar
MAF Sensor CLEANING
anyone ever clean their Mass Air Flow sensor. i wanna clean mine cuz i can clearly see oil and dirt on it? what should i use to clean it?
Old Oct 1, 2005 | 12:17 PM
blksnake's Avatar
+1
Old Oct 1, 2005 | 02:03 PM
2002 Maxima SE's Avatar
Rubbing alcohol and Q-tip or Electronics parts cleaner.
Old Oct 1, 2005 | 03:11 PM
EricIsKlumzyee's Avatar
^ yup
Old Oct 1, 2005 | 06:45 PM
binar's Avatar
Electronics parts cleaner works well, I have used CRC QD Electronics Cleaner.
It is a quick drying formula that works very well. I would touch
the wires. The sensor is very expensive and spraying with an areosol cleaner
allows the MAF to be cleaned without touching the wires.
Old Oct 1, 2005 | 08:19 PM
OOOOA3's Avatar
Alumni****
i just use rubbing alcohol.. just make sure you wipe it realy clean..
Old Oct 1, 2005 | 08:38 PM
Hooman6MT's Avatar
20 Year Member
how often does this need to be done? What's the consequence if it isn't done, CEL?
Hooman
Old Oct 2, 2005 | 01:02 AM
Derek S's Avatar
Hooman
i just had mine messed up by the pop charger filter oil so im just ganna clean the MAF sensor before it gets any worse. its not like a oil change ware you have to do it.
Old Oct 2, 2005 | 04:47 AM
borahatch's Avatar
Can you elaborate on the problems you had? I just cleaned and reoiled my Injen filter. I don't want to run into problems.
Old Oct 2, 2005 | 02:48 PM
Derek S's Avatar
i would get low idel and my car would staul at low RPM turns and its a AT. i put back the air box and just kept the z tube and im fine now but i dont want the oil on the sensor to pick up anymore dirt so thats why im cleanign it.
Old Oct 2, 2005 | 03:54 PM
borahatch's Avatar
Thanks a lot! That's something I'll keep a close eye on because, like I mentioned earlier, I just re-oiled my filter. At least if my car starts acting up, I'll know what to look for.
Old Oct 2, 2005 | 06:06 PM
Derek S's Avatar
man that CRC QD Electronics Cleaner works good i just sprayed my sensor wow i can see the sensor shineing. thanx alot its just like new. knock on wood.
Freeman186
Sep 6, 2023 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
