What speed not to exceed during break-in.
Old Jul 21, 2003 | 06:52 AM
Deacon8700's Avatar
What speed (MPH) should you not exceed during the initial 2,000 mile break-in preiod?
Old Jul 21, 2003 | 08:34 AM
bigel's Avatar
Re: What speed not to exceed during break-in.
155
Old Jul 21, 2003 | 09:19 AM
BMW3toG35C's Avatar
It's in the manual: during the first 1200 miles don't exceed 4000 RPMs, don't accelerate hard and don't hold RPMs steady for prolonged periods of time. Don't brake hard either. That's about it.
Old Jul 21, 2003 | 12:10 PM
tpware's Avatar
says 60, but thats not always safe.. I wouldnt do over 75. I dont think the wheel bearings need *that* long of a breakin. But I wouldnt heat them up much right off the lot. Same with the tranny.. Try not to build up too much heat.
I've heard of failing wheelbearings on 5th gen maximas, so its not unheard of.
bs g35c lth/prem - a poser with no lsd
Old Jul 21, 2003 | 01:12 PM
infidsg35's Avatar
These motors are already broken in right after they build them in Japan.. Just change oil right away like 1k - 1,500k and you will be set..
Old Jul 21, 2003 | 02:26 PM
tpware's Avatar
not true.. Toyota & Honda yes, Nissan no...
BTW, you make the most HP at 5K. Another difference is that the VQ is a 200K+ motor, the others are generally not.
Old Jul 23, 2003 | 05:12 AM
ryoken's Avatar
Motor's probably fine, but you're also breaking in the transmission and drivetrain components.
Old Jul 23, 2003 | 11:05 AM
Aftrbnr's Avatar
I was told the same as BMW3......they also said not to break 100 mph.
Old Jul 23, 2003 | 04:04 PM
shelleycat's Avatar
a tech at a dealership from Infiniti manufacturing said they do not break in the engine before or after they install it in the car. They just make sure it works, put it together and ship it out.
"Moderation in all things, including moderation."
Old Jul 23, 2003 | 04:38 PM
Cali_Eddie's Avatar
Agreed.. Anything over 100 is a no no...
G35 Mafia Member # 01
Old Jul 24, 2003 | 08:09 AM
Jedi's Avatar
My cents. I agree that it is my belief that you should not exceed 100 MPH during break in, prolonged RPM rate i.e. Long Fwy usage, is probably not good on motors that support Variable timing, or so that I have heard. Can someone educate me on the VQ, is it variable timing controlled?
"Use the Forced Induction Luke!"
-Jedi
2003 G35C, 6MT, Navi, Black Obsidian/Graphite
KruZZe
Feb 27, 2023 05:04 PM
aaron3719
Sep 29, 2015 10:12 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
gatorglaze
Sep 19, 2015 12:06 PM
dorkstar
Steering & Suspension
Sep 16, 2015 01:02 AM
