engine squeal on start up..
Old Oct 28, 2005 | 06:14 PM
Patrick952's Avatar
sometimes on start up i here this loud squeal that last about a second and then goes away... car drives fine, no problems beyond that..im wondering what it could be?
Old Oct 28, 2005 | 06:25 PM
twinsnails's Avatar
tighten your belts
Old Oct 28, 2005 | 07:39 PM
Patrick952's Avatar
tighten the belts??? u can actually tighten them>??? i thought they have to be changed
Old Oct 28, 2005 | 08:50 PM
GonSpeed's Avatar
Originally Posted by twinsnails
tighten your belts
It could be the belts are just loose, but sometimes what causes it is too much freon in the A/C.
Old Oct 28, 2005 | 09:20 PM
RBull's Avatar
Rated M
Can you explain that one??
Old Oct 28, 2005 | 09:24 PM
GonSpeed's Avatar
yea i can. It probably isnt your problem but i used to work on cars and we used to fill the a/c compresor with freon and if you put to much in it will cause the belt to squeel and not spin properly.
Old Oct 28, 2005 | 09:37 PM
RBull's Avatar
Rated M
Thanks, I've never heard of that one, especially. This must put some kind of extra load on the compressor when the air conditioning is on and the switch kicks it in.
Old Oct 28, 2005 | 11:32 PM
Deang35c6's Avatar
Did you just get a crank pulley mod? This is usually something you have to deal with until the new belt wears in.
Old Oct 29, 2005 | 02:10 PM
Patrick952's Avatar
no but i did just get the freon filled cuz i had a mishap with the rad... WEIRDDD
Old Oct 29, 2005 | 04:51 PM
twinsnails's Avatar
I've never heard of the freon being too full causing belts to slip. That's good to know! I have seen bad alternators or a short (extra load on the alt) cause the belts to slip. But it is very rare and only seems to happen to us car audio nuts!
andyg35c1
Aug 29, 2015 03:37 PM
G35CO
Aug 25, 2015 02:00 PM
chinee
Aug 8, 2015 10:11 AM
Terry_G35
Aug 4, 2015 02:38 PM
newg37
Jul 26, 2015 09:32 AM
