No Tint W/ Navigation?
My 2 week old 06' 6MT does not have a nav or tint; however, the Beamer which I traded in had darkk tint and nav. The nav was flawless.
I suggest taking the car to a different tint shop who will warranty the nav reception.
Agreed, I have Formula 1 tint all around w/Nav. and it works fine if you do not get the reflective tint.
Check www.thetintpros.com and give them a call.
Originally Posted by dofu
Yeah that... reflective tint is what you want to stay away from, regular tint is fine. The metal will either trap the signal from your navi, or keep it from recieving (don't remember which) kind of like how the signal's distance from your key fob of your alarm is reduced when you install the alarm under the metal of your car, etc...
I can't say definitively whether or not metallic based tint would or would not cause a problem, but I can understand how it might.
Personally, I would avoid dye based tint. It does a poor job of really keeping out heat and UV.
I went with the Huper Optik ceramic tint, and it works unbelievably well. The downside is that it's definitely pricey, and even after 2 months, I'm still having some issues with the way it set (or didn't set, for that matter). But from a performance standpoint, it does a better job of reducing heat than any other tint I've experienced.
get ceramic tint (its non conductive).....i have an 06 and i got 28% metallic tint on the sides and 15% ceramic on the back.....i have the formula one pinnacle tint thats on the back and the ultimate for the sides
newbdriver01
Jul 15, 2015 06:10 PM
