6MT sucks
Old Nov 19, 2005 | 02:15 PM
  #31
Sumlime311's Avatar
dang that sucks, should have got a 5AT
Old Nov 19, 2005 | 06:01 PM
  #32
LIUser's Avatar
i have an 05 6mt and every gear is smooth, shift between 2500-4500 usually, occassional WOT, but rarely, its fast enough for me
Old Nov 19, 2005 | 06:36 PM
  #33
partyman66's Avatar
NOT!!!
Old Nov 19, 2005 | 06:46 PM
  #34
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Absolutely No Probs wit my 6MT bro... Sorry to hear yo grief
Old Nov 19, 2005 | 06:55 PM
  #35
shodog's Avatar
I suspesct it's the way you drive in stead of the tranny. are you sure you are pushing the clutch all the way in as you shift from 1-2? you might need to move your seat forward a slight bit. is your floor mat interfering with the clutch throw?
Old Nov 20, 2005 | 06:56 AM
  #36
brittain's Avatar
'04 with 22K and no problems at all.
Old Nov 20, 2005 | 08:35 AM
  #37
chops's Avatar
I would get a truck if I had to drive AT.
Early 03 here and no problems. Vortech's been on for over 6k
Old Nov 20, 2005 | 02:38 PM
  #38
htownboy's Avatar
Same here except I have an 04.5 with an 05 6MT (yes it was replaced) and it great in any gear in any range.
Old Nov 20, 2005 | 04:34 PM
  #39
g35nightrider's Avatar
Yeah, I have an 04 6MT and its running awesome. Got about 32k miles on it, and it was fun getting those miles on. I drove other stick cars and they are so easy especially with the clutch and everything. However I found the G is a little jerkier between gears, depending on your RPM's. I was at the track and the trainer told me the reason for that is because it is a high performance car. After a while you start to find it's sweet spots in the RPM and you get use to the car. This is no civic. It has a highly responsive stock clutch and tranny. Get use to it.
Old Nov 20, 2005 | 07:31 PM
  #40
G35Gnome's Avatar
I got a 05 6MT and 4.5k miles on it no grinding or anything, ever. It was a bit hard to shift 1-2 but I got a good hang of it by now and there arent any issues and I usually shift into 2nd well above 3krpm (more like 4.5-5k). The only thing is that the 1-2 shift feels nothy(especially when cold), any other shift combo is nice and smooth.
Old Nov 21, 2005 | 06:05 PM
  #41
Disco_Monkey's Avatar
My 6MT is perfect. I had a couple of mis-shifts at redline before I got my Rogue short shifter. Now I can chirp it from 1-2 and 2-3... no more mis-shifts.
Old Nov 22, 2005 | 03:28 PM
  #42
da45king's Avatar
used to have those issues....I changed to mobil 1 synthetic manuel trans fluid and the diffential fluid and there is no more 1 crunch 2 for me. I have 53k on the car
Old Nov 22, 2005 | 03:35 PM
  #43
4thHorseman's Avatar
2004 6MT with 29K miles, no problem. Take it to the dealer, man.
Old Nov 22, 2005 | 03:49 PM
  #44
UFGatorG35's Avatar
I skipped right to the end as I am in a little hurry so sorry if I am reposting info...
The synchro problem was in the 03-04 transmission. What year is your car?
Our problem was quickly resolved, new tranny with no push back from the dealer. Before repairs there was some grinding but definitely no trouble getting into gear (as least in my case). Is the clutch all the way down? You may have driven a lot of manuals before, but this one is one of the least forgiving I've ever driven.
If you are still having trouble, as so many have already said, take it in to be checked out. Once you get it worked out you will not regret getting the 6MT, trust me.
If you dont like the feel of the gear box, you must not truly enjoy shifting IMO
