Jacking points on the coupe
Old Aug 1, 2003 | 01:47 AM
bkchang79's Avatar
I found a good place to buy floor jack and jack stand pads
http://www.protechproducts.net/images/JACKPADS.asp
Question is that there are only 4 jacking points. Where and how do I place a jackstand on the side when I'm jacking the vehicle up since there's only one jacking point on the front and another in the rear? I don't want to rely on the floor jack when I'm under the car.
2003 G35 Coupe 6mt Diamond Graphite
Old Aug 1, 2003 | 12:10 PM
3point5SE_Auto's Avatar
Re: Jacking points on the coupe
i use a long piece of wood (at least 3/4" thick) to lay on the jack.
I use a piece about 2 ft long. then i locate it under the longitudinal body rail and jack it up. this way you can jack up two wheels at the same time and then place your jackstand wherever you want. I prefer to place my jackstands under the suspension arms on the front and rear suspension, as I have made some minor damage using jackstands on my designated jacking points
Better Life thru Chemistry
Old Aug 1, 2003 | 01:50 PM
bkchang79's Avatar
wouldn't placing the wood on the rails damage the plastic painted piece?
Old Aug 1, 2003 | 11:09 PM
zorro's Avatar
I think this is a good question, and detailed professional instructions would help greatly. There was a post that explained step-by-step how to change your oil, and I think we need something similar for "jacking your G".
Old Aug 2, 2003 | 05:56 PM
Gordgee's Avatar
Administrator
Done. I'll post the jack points on FAQs.
<font color=green>GG</font color=green>
Old Aug 2, 2003 | 10:01 PM
bkchang79's Avatar
I don't think I trust the suspension arms for a jack stand point. I still don't understand how I can get a floor jack and place the jack stand on the designated jack points on the car.
bkchang79's Avatar
here's another angle
Old Aug 3, 2003 | 01:20 AM
Spyder500's Avatar
do you really need those jack stand adapters?
I used it once with out the adapters... where do I buy or make them?
I haven't jacked the G up yet from the front... but supposedly from the Manual it says theirs a middle jack point for the front. Is it really impossible to reach?
I have one of those huge 3ton hydrojack. And do you need an adapter for the hydrojack?
Need to know how to properly and safely jack it up.... going to need to do an oil change soon.
Old Aug 3, 2003 | 03:12 AM
zorro's Avatar
Thanks Gordgee, I'll try this out next time.
Old Aug 3, 2003 | 10:18 AM
TX_G35's Avatar
Without the adapter, the floor jack will crush the metal rail. eastwoodcompany.com sells this one. Works great on the G35 and my wife's TL.
Old Aug 3, 2003 | 01:20 PM
Gordgee's Avatar
Administrator
The saddle I have pictured on FAQs replaces any stock saddle with a 1 3/16" shaft. It features a 4 3/4" square rubber pad with slots for the body sill rail, and because it's rubber, isn't hard on the paint and metal (I hate that cunching sound), and spreads the load quite nicely. I got it at Princess Auto for those of you Canucks near a store, and I think they can be had on-line at www.princessauto.com for $8.99 CND! Not sure if they ship to the States however.
Old Aug 3, 2003 | 04:55 PM
bkchang79's Avatar
Ok, so far no one has answered this question "I still don't understand how I can get a floor jack and place the jack stand on the designated jack points on the car."
Old Aug 3, 2003 | 05:23 PM
wreck's Avatar
Running for his life!!
In your case you have to use the floor jack to jack up the front 2 or back using the floor jack points(garage jack point) in this thread in FAQ.
https://g35driver.com/forums/showfla...sed&sb=5&part=
G35C 6MT / AMG E55<P ID="edit"><FONT class="small"><EM>Edited by wreck on 08/03/03 02:25 PM.</EM></FONT></P>
Old Aug 3, 2003 | 06:10 PM
Spyder500's Avatar
wow that Jack Adapter $20
and the Jack Soft Pad $20
That shiz aint cheap!
Old Aug 4, 2003 | 06:44 PM
there is another unpainted rail further in . getting a floor jack to that front jack point is a bitch, make sure you run up the front wheels on a two by four or something to get it up a few inches first.
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
DRG35R
Jul 31, 2015 10:23 AM
rping
Jul 26, 2015 09:53 PM
