Service Engine soon warning light is on
Old Dec 29, 2005 | 04:36 PM
G35cJ's Avatar
I have a 04 coupe with about 5,000 miles now. Yesterday when I started it in the morning, there were several warning lights kept on even after the engin started running. I recall they were SLP, VDC and "service engine soon" and maybe couple of others. I then turned the engine off in my driveway and restarted it again, and this time, only the "Service Engine Soon" light kept on. It remaind on for the two trips I made for about 90 miles yesterday.
Flip through the manual, it says this maybe emmission related and might be going away after a few trips. I checked my gas cap, and it was tight and with about half tank of gas. Any one has a clue what this might be? I hope this is nothing serious.
Old Dec 29, 2005 | 04:47 PM
LjN_728's Avatar
I'm just friggin' surprise you only have 5k miles on an 04'. Wow...
Old Dec 29, 2005 | 05:03 PM
Msedanman's Avatar
O.F. Administrator
You can either get someone to read the code with a scanner, and then reset MIL for you, or you can reset the ECU to reset the MIL yourself.
If it comes back, have the dealer find out what's causing it to come on.
It's probably a pollution control sensor gone bad.
C.
Old Dec 29, 2005 | 05:04 PM
G35cJ's Avatar
yeah, I bought it Oct. 2004, and have not driven it much. I don't know if this light usage caused problems like this.
Old Dec 29, 2005 | 06:22 PM
luongdmd's Avatar
light is probably telling you to drive it more....... j/k go to autozone.... they have the obdII scanner, and they'll let you know why the light is on..... OR go the the infiniti dealer..... you should still be on warr.....
luongdmd's Avatar
Old Dec 29, 2005 | 07:04 PM
Ralphanator's Avatar
I have 21,000 miles on my 05C and no check engine light so far! Take it in and have the dealer check it out!
Old Dec 29, 2005 | 07:14 PM
99atlantic's Avatar
Mine did that twice - ses engine light just came on for no apaprenty reason. unplug the battery and it'll go away.
i only have 7000miles on my 03 (bought jan 03)
Old Dec 29, 2005 | 07:49 PM
WILD121's Avatar
the dealership should take care of it for free
Old Dec 29, 2005 | 07:59 PM
99atlantic's Avatar
the fact you drove to them w/o problems will tell them that your car is probably fine and not to waste any time on it - they'll just reset the ECU and claim they looked at it and it was just a random error, lmao. Avoid teh stealerships when possible.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
derres
Aug 28, 2015 03:27 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
mjfenix
Jul 17, 2015 02:07 PM
