Post pic of 'wire loom on transmission housing'?
Old Jan 12, 2006 | 01:27 AM
99atlantic's Avatar
I'm reading instructions on installing a grounding kit (to figure out if I can do it myself), and installing wire #7 (not certain if all kits use the same stuff, but I'm reading the z-xtreme guide since its the only published 1 i can find) it says:
Remove the 10mm bolt securing the strip clamp holding a wire loom on the transmission housing.
Anybody have a picture of that? or can perhaps tell me on what page of the service manual to look at to find a diagram of the location of the bolt securing the strip clamp holding a wire loom?
Old Jan 12, 2006 | 01:50 AM
G352NV's Avatar
Never enough
Just get under the car and you will see it.
Old Jan 12, 2006 | 01:54 AM
99atlantic's Avatar
You wouldn't believe how car stupid I am.....I doubt I'd be able to find it....can you atleast tell me where to look? ^_^
Old Jan 12, 2006 | 02:08 AM
G352NV's Avatar
Never enough
Its on the passanger side toward the front of the tranny. Just look for the black loom.
Old Jan 12, 2006 | 02:30 AM
99atlantic's Avatar
Okay, next stupid question, what is a 'loom'
(see, i told you i was car stupid )
Old Jan 12, 2006 | 08:32 AM
maxpower's Avatar
which kit are you installing? there are pictures for Gordees kit available. the wire to the trans is bolted to the transmission on the passengers side, it is easy to see from underneath the car. you will need to have it on jack stands or a rack
Old Jan 12, 2006 | 08:40 AM
giddyup69's Avatar
i've attached a sample pic of a black wire loom. a simple search on the internet would have given u the answer btw.
Attached Thumbnails Post pic of 'wire loom on transmission housing'?-xoxide_1881_145593458.gif
Old Aug 10, 2014 | 10:26 PM
The_Silencer's Avatar
Funny, I just installed mine today and I believe its the same kit as yours since I bought my 7 wire kit from z-xtreme and the instructions are the same word for word. I mounted mine here: https://g35driver.com/forums/attachm...sion_lower.jpg. It's on the left (driver) side of the tranny since it's the only place that I can find that matches the description. I followed the instructions as described and the wire is actually long enough to reach the bolt point. Huge pain in the *** though and I don't think it was possible for me to undo the bolt without a mini ratchet.
Old Aug 10, 2014 | 10:30 PM
Urbanengineer's Avatar
Thanks for answering this thread... Somebody might find it useful .
newg37
Jul 26, 2015 09:32 AM
simperformance
Jul 24, 2015 11:17 AM
nervseele
Jul 17, 2015 11:21 PM
