Re-flashing the ECU
Old Jan 18, 2006 | 03:52 PM
99atlantic's Avatar
Re-flashing the ECU
If you reflash the ECU, then at a later point disconnect the battery to clear its memory, when the battery is re-connected will it retain the settings that were flashed to it, or will it default to the factor fefaults?
Old Jan 18, 2006 | 04:04 PM
briphi's Avatar
Flash memory persists without power, the settings should stay.
Old Jan 18, 2006 | 04:32 PM
99atlantic's Avatar
key word being 'should' ^_^
Old Jan 18, 2006 | 04:45 PM
Msedanman's Avatar
O.F. Administrator
According to Technosqaure who do the reflash, disconnecting the battery will not cause ECU memory loss.
I'm trying to find the website addy for you to refer to. As soon as I locate it, I'll post.
C.
Old Jan 18, 2006 | 04:48 PM
Devil Dog's Avatar
C.
http://www.technosquareinc.com/index.html
Old Jan 18, 2006 | 04:50 PM
Msedanman's Avatar
O.F. Administrator
Found it:
http://www.technosquareinc.com/contact.htm..
All the info you need.
C.
Old Jan 18, 2006 | 05:03 PM
briphi's Avatar
Common people, you should know it won't loose it's settings. Do flash cards loose your pictures when you take them out of your digital cameras? That's how flash memory works.
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
MThawkins86
Oct 24, 2015 02:07 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
