Please! help me find a squeak
Old Jan 31, 2006 | 07:38 PM
Derek173's Avatar
My 03 coupe recently devloped a squeak somewhere in the rear that has been driving me nuts all week!
I believe it is coming from the rear, not sure if it is the suspension, maybe a bushing gone bad?
Only occurs on rough surfaces, you can hear it on bumps but its really apparent on rough roads. My car has had small rattles here and there but this one is just bad
Old Jan 31, 2006 | 08:16 PM
MikeStarrG35's Avatar
Obsessive Owner
hmm, im not sure. I have an 05 coupe and I am getting a squeek from my center glovebox (i think). It is a high pitched squeek over rough surfaces or when I am keeping my arm on it, and it can sound like its coming from the rear. Not sure about what else it could be.
Old Jan 31, 2006 | 08:54 PM
Dan_K's Avatar
I had a rattle in the right rear of the cabin where the antenna is located. It came loose and always shook when changing lanes on the freeway. So it might be that.
Old Jan 31, 2006 | 09:28 PM
Derek173's Avatar
thanks guys keep them coming! I will search and destroy this weekend.
Someone mentioned it might be the sway bar bushings. That might not be such a bad thing (stillen sways + poly bushing FTW! )
Old Jan 31, 2006 | 09:49 PM
Knight's Avatar
I've actually have a similar squeeking problem in the rear too, mine is specifically on the passenger side rear. I notice it tends to make more noise over rough surfaces & when the weather is colder.
I have the Tein CS installed on my 04 coupe, so I'm under this impression it's the coilovers creating the noise? Before the suspension upgrade I had no noise. Any suggestions?
Thanks!
Old Jan 31, 2006 | 10:39 PM
gizsf's Avatar
Clip your front and rear seat belts too before you go on the noise hunt and make sure the back seats are fully locked.
Old Jan 31, 2006 | 10:41 PM
Derek173's Avatar
Thanks!
ill keep you informed if i hear anything. I have stock suspension and it sounds like we have the same exact problem, do you track your car? Im thinking it might be a bushing (sways maybe?)
Old Jan 31, 2006 | 10:43 PM
Derek173's Avatar
ok so the button at the top of the back seat should be in the up or down position if locked?
Old Feb 1, 2006 | 12:22 AM
TimW's Avatar
i have it too, was told it was probably bushings. They offered to replace them on my next visit. My coupe is a may 03 build, started squeeking a few months ago.
I got a loaner FX for other work being done last Friday, on the same rough patches, the FX made the same exact sounds
Anyway, I've been fighting the substandard rubber used on the sunroof. So, I wouldnt be surprised if the bushings were not of the highest quality.
Old Feb 1, 2006 | 04:35 AM
Derek173's Avatar
Please PLease, Find out exactly what was wrong, with part #'s if possible. Sounds like the same problem as me. How many miles you have on your coupe.
Still hoping its the sway bar bushings
Old Feb 1, 2006 | 12:03 PM
300zx2G35's Avatar
No idea whats going on
Thanks!
+1 on the same exact problem but I have the Tein Flex and i can't tell exactly what side the noise is coming from.
I can kind of understand when it's cold for it to squeek because maybe the metal is cold and has to warm up or something
Old Feb 1, 2006 | 07:06 PM
Derek173's Avatar
Do you guys with lowered suspensions track your car? Im thinking the track days may have worn out a bushing on my car (hopefully sway bushing )
Old Feb 1, 2006 | 07:20 PM
Knight's Avatar
With everything locked (seatbelts etc) I still hear the squeaking sound.
I do not track my car too, it's only used for regular city driving. It only just started about 6 months ago, and my G has only 24,000 kms on it. Unfortunately I do not see a TSB for bushing replacment.
The bushings theory does sounds logical, for those with stock suspension I think the dealer should be able to help you out. However for us with upgrades in suspension, depending on the dealership they may claim the swap in suspension is the problem.
Anyone else have issues with their bushings?
Much appreciated!
Old Feb 1, 2006 | 08:59 PM
Derek173's Avatar
i just heard from others that it might be a sway bar bushing. Dont know myself.
Much appreciated!
Old Feb 1, 2006 | 09:11 PM
mosdefconor's Avatar
My car has a squeak as well
It sounds like it's coming from the rear wheel on the passenger side and when I called the Infiniti dealership the mechanic said that it might be caused by the fact that my brake pads are worn out and it's rubbing against the rotor. That sounds plausible except for the fact that the noise often comes when I'm not even touching the brakes. I'm taking it to the dealer soon and will let you guys know what I hear.
But there is definitely a part rubbing against another. Hope we can get to the bottom of this.
