Grinding noise 6th or 7th time already - HELP
Old Feb 21, 2006 | 12:57 AM
cloud's Avatar
I have had the car since october 05 and I know how there is an ABS check after u start the car and drive above 10mph. But for the past month, the sound has sometimes changed from the sound of something being reeled in to a mean grinding sound. It doesn't sound like a gear grind but something lighter. Sounds exactly like scraping your body kit when going through a speed bump except a little metallic i guess.
It only happens after starting the car and taking off(when it happens I do not hear the ABS "reeling sound" I hear that mean grind instead)
What could be wrong?? (note: this happened around the same time i started having weird "worn spring" noises and occasional "prickling" sensations in the clutch pedal.)
Old Feb 21, 2006 | 04:05 AM
cloud's Avatar
*bump*
Old Feb 21, 2006 | 12:56 PM
cloud's Avatar
It doesn't happen often enough, probably once a few days so I'm not able to replicate the sound. I'd appreciate it if anyone who has any theories / experience with this could help me out.
Old Feb 21, 2006 | 04:32 PM
crazyg35coupe's Avatar
FGC General Member
i had the same issue....i tryed asking people and no one had the answer....it doesnt happen all the time...and only happens when u start it up in the morning...i took it in for service thinkin it was the tranny and they couldnt duplicate the error. it hasnt happened since....but i have tryed lettin my car warm up longer before i drive off......seems to help....if u find anything let me no...and goodluck
Old Feb 21, 2006 | 06:56 PM
cloud's Avatar
has no one else had this problem?
Old Feb 22, 2006 | 01:02 AM
jmeli11's Avatar
I've had the same problem going up slowly on a driveway in gear... dunno what it is. Hope someone knows
Old Feb 22, 2006 | 01:41 AM
2Evolved's Avatar
hey I get that too... I think... if it's how your describing, I really notice it in the morning when I reverse out of my parking.
sounds like sort of a ringing light grind noise... I haven't really thought much of it.
Old Feb 22, 2006 | 01:47 AM
TAR82's Avatar
i have the very same issue with my 06 coupe, i get the same grinding noise... but only comes once in awhile when i first start my car, im going to mention it to the dealer when i go on the 27th for an alignment check and some other weird water noises coming from somewhere??? my service dept is so sick of me but o well.
Old May 1, 2006 | 08:41 AM
Gashed's Avatar
Any new info?
Any new information on this? It is happening in my '04 coupe as well, some mornings not so bad, some very bad. This morning I had a grind upon start that sounded really bad.
Thanks.
Old May 1, 2006 | 09:41 AM
JDM 350GT's Avatar
there were so many threads regarding the grinding issue and i cant find it!
Old May 1, 2006 | 04:00 PM
Gashed's Avatar
Might have something to do with the timing belt? Check out this thread:
https://g35driver.com/forums/showthr...grinding+noise
Old May 1, 2006 | 04:50 PM
sesegal99's Avatar
no no no.........it is your breaking / vdc system checking itself. It does a self diagnmostic check real quick and it only does it when you first start and then go no faster than about 10 miles per hour for the ferst few seconds. I can get my car to do it whenever I want. It is normal. It is sorta a quick clicking sound for about 2-3 secs.
Old May 2, 2006 | 04:51 AM
Fassster10's Avatar
SESEGAL99 are you sure its the VDC system...ive told the dealer about 3 times about the noise, i got my aligment, change the brakes, and all the fluids and still got that darn noise...it just seems odd that the VDC system would make that noise and there woulnt not be any notice in the manual advicing of it you know...i dont know... i documented the three times i asked the dealer anything breaks because of that noise or whatever they need to fix it free of charge...
Old May 2, 2006 | 08:26 AM
Gashed's Avatar
What I don't understand is why some mornings when I start the silver bullet there is that terrible grinding sound, other mornings it is not as loud, and still other mornings there is no sound at all after start up. I always get another grind as I get going but I think that is the ABS check.
Old May 2, 2006 | 12:04 PM
cloud's Avatar
exactly, there is the usual grinding noise(soft) which is the ABS check and the terrible grinding noise(like sounds scraping your body kit) which is the problem I believe we're all referring to.
