DIY Oil Change
Old Feb 27, 2006 | 07:11 PM
ozracer01's Avatar
Originally Posted by Gdup35sedan
40K car ---> I'll do it myself so i know it gets done right and i dont have some dooche bag tech at the stealership working on my car, plus you get more of a sentimental value for your car if you work on it yourself.
-GP-
+1..
Old Feb 27, 2006 | 07:38 PM
redlude97's Avatar
not sure if I read it right, but did you check it with the engine on? I'm not sure about the G, but most cars need to be checked when the engine is off and the oil is allowed to settle in the pan. Then the stick should be wiped and then redipped. What you may be seeing is splashing onto the stick from engine movement, thus the high level
Old Feb 27, 2006 | 07:42 PM
Real_G's Avatar
An Army of One...
-GP-
Well, its kind of hard for a "stealership" to not do an oil change wrong..
My dealership is actually pretty good so far. Sentimental value.. blah.. I had that with my last car.. I did everything.. from CF Hood, CAI, Springs to Coilovers, Stereo... Ive had enough "sentimental value"!
As TI would say.. Do ya thang!
Old Feb 27, 2006 | 07:48 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Real_G
While i agree its hard for them to do an oil change wrong, it's been done, i just dont trust them with the car i work my a$$ off to pay for. If you have a good dealer then more power to you but some people arent so fortunate. to each his own
-GP-
Old Feb 27, 2006 | 08:07 PM
jgainnm's Avatar
I'm with you. I take my car to the dealer because they do a great job, and have found a couple of things I would have missed. Besides, I can go there and be back home within 2 hours - and get some fresh baked cookies and coffee while I wait, if I don't want a loaner.
Old Feb 27, 2006 | 08:31 PM
Real_G's Avatar
An Army of One...
I like getting the loaner! Ah, yes, the cookies and coffee...
Old Feb 27, 2006 | 11:48 PM
SinG35c's Avatar
Last year I took my Odyssey to a Honda dealer for a "simple" oil change. Guess what? The douche who worked on it didn't put a drop of oil in the freakin car! 2 minutes driving down the road, the engine gave in. It only had 12k miles
Old Feb 28, 2006 | 10:26 AM
superb16's Avatar
40K car ---->> Let the dealer do it.
Always easy to spot the non-enthusiasts in the bunch. The G35 is the eeeeeasiest oil change in the history of oil changes. No way would I pay a dealer for that unless I'm just afraid of getting my hands dirty.
Old Feb 28, 2006 | 11:19 AM
vjquan's Avatar
Maxima 4th generation. No undercover to remove and no jacking up required.
Old Feb 28, 2006 | 12:29 PM
G-ThreeFizzle's Avatar
^^ so true...I had a 4th gen maxima before my G as well, and no jack required, even though my car was dropped...very quick/convenient.
Old Jul 5, 2006 | 04:15 PM
ashadiow's Avatar
You are all wrong. the 3000GT and stealth's are the easiest. seriously.
Old Jul 5, 2006 | 04:44 PM
saitcho's Avatar
i dont know about the easiest. somewhere around the 16th or 17th bolt on the undercover i was pretty frustrated. 20 bolts for one undercover is just a mystery to me.
Old Jul 5, 2006 | 05:21 PM
Down_Shift's Avatar
No one wants to touch my G, it's too low not worth their time.
Plus I like to get under there to make sure there isn't leaks etc..
It is a b#tch though.. takes me a while to get it up.. and like 10 min to do the oil change lol..
I don't even use the dip stick anymore. 6 quarts (I have the spacer) and forget it.
Old Jul 5, 2006 | 05:59 PM
bythabay's Avatar
I've serviced several Gs who had previously only been to the dealership and I've seen some crazy things left behind. The last G I had over in my garage had 2 crush washers smashed into each other and to boot the drain plug was tightened beyond the 25ft/lbs that infiniti specs.
I always replace the crush washer with a new one and remove the old one.
do it yourself, save some money, and have piece of mind.
the right tools can make the entire job take about 15 mins
Old Jul 5, 2006 | 06:22 PM
  #30
gary c's Avatar
Yea, do it yoself........
First off I would never use ramps.....jack and jackstands....just my thing! Since your using good
oil why use inferior filters....K&N filters on line for
$8 and if you buy three delivery is free....HP 1008.
You changed to Mobil 1 at 1k and that's OK.....I
couldn't stand having the factory oil in my G and I
changed mine to Mobil 1 @ 800 miles....I'm almost
to 13k and don't use a drop between changes! Five
quarts takes my level to H on the (wonderful) dip
stick.....you know you have to remove the d/s
wipe it off and reinsert it a second time to get a
true reading? LOL
