Year / Mileage / Problems
Old Mar 7, 2006 | 12:28 PM
keib's Avatar
'06 MT coupe:
2 speeding tickets.
No rattles...am I deaf?
Old Mar 7, 2006 | 12:42 PM
elau's Avatar
'04 5AT
Miles: 9,600
Rust along inner weld seams on trunk lid - not fixed
Rattle from steering wheel - not fixed
Rattle from driver door - not fixed
Old Mar 7, 2006 | 12:49 PM
Itoaccp33's Avatar
03 5AT
Miles 72,000
Low beam headlights short out - not fixed, dealer charges $570
seats squeak - will look into when it's warmer
Blows stereo stops playing CD's mid song - not fixed, saving up for DD kit
Old Mar 7, 2006 | 01:47 PM
mike552's Avatar
2004.5, 17Kmi
-Wind noise at 50mph+, fixed: replaced pass door seal.
-Rear axle clicking noise, fixed: TSB.
-Sunroof creaking noise, fixed: wiped dust off rubber seal when sunroof is open.
-Brakes squeaking at 10000mi, replaced under warranty.
-Gas cap lock motor noise, fixed: replaced servo.
-Car pulls slightly to right, NOT fixed: will address at next srevice.
Old Mar 7, 2006 | 01:52 PM
chops's Avatar
2003
17k miles
Problems:
No traction in 1st and 2nd Gear.
Old Mar 7, 2006 | 03:50 PM
G35MC's Avatar
rattles while idle.
Old Mar 7, 2006 | 05:14 PM
B GrAzi's Avatar
2005 5AT
3200 miles
Prbs
Loosened Control arm bolts on right side front and rear(600 miles) dealer fixed..warranty work.
Rear splash Gaurd right side has come loose(i think it is missing one of those black clips but i have not checked)
No rattles so far knock on wood
Old Mar 7, 2006 | 06:21 PM
brisk's Avatar
2005 6MT
~5000miles
Problems:
Rattle from steering wheel (Trying to fix for the fifth time)
Rattle from Pass. rear
Rattle from vents
Car pulls slightly to the left at speeds over 50mph
Old Mar 7, 2006 | 06:38 PM
2Evolved's Avatar
2004 6MT 30k miles
- left side speaker blows out frequently dealer: replaces speaker problem persists, dealer replaces head unit problem solved.
- doors do no unlock manually, dealer replaces cables problem solved.
- whistling window above 60mph, dealer adjusts window and still whistles haven't gone back lazy and used stereo to block out the sound.
- no spoiler on the car, paid dealer $900.
So far no rattles or engine problems but who should have engine problems at only 30k.
Some people should list there mods along with problems
Old Mar 7, 2006 | 06:58 PM
brikkman's Avatar
2003.5 6mt (stock)
Brought used at 25k
Problems between 26k-29k
rear view mirror rattles (drove me crazy) - fixed
Driver seat squeaked (drove me crazy as well) -fixed
squeak coming from a/c when turned on - fixed (pulleys bad)
squeak coming from heater - can't be reproduced to be fixed
Old Mar 7, 2006 | 07:23 PM
east1999bt's Avatar
04 6MT loaded, coming to 20k miles, initially (for about the first 10k miles), brembos squeaked a lot, dealer didnt do anything about it b/c i couldn't duplicate it there. had the Clutch pedal assembly/linkage replaced under warranty, there was a "recall" or bulletin on that because of clicking when I shift betwee 1/2/3rd gears at around 13k miles
many rattles, i dont know from where and its bearable for now b/c my sound system is on 95% of the time.
Old Mar 7, 2006 | 09:35 PM
htownboy's Avatar
47,500 miles 2004.5 6MT Prem TB\Graphite
*3rd. Trans; this last one has been there for 32K and is sweet, first got stuck in 5th. and had to be trailered in, 2nd. one had a shift rod break a couple of days after installed; 3rd. has been sweet since day one and will shift at any RPM in any gear very smoothly & quietly!
*Axle clicking noise TSB at 22K
*Seat belts not retracting well lateley, not at all sometimes - will take in soon.
*On my 6th, or maybe my 7th. or 8th. set of rear tires, second set on front, need all 4 again very soon..
+No rattles - Fingers crossed
+Awsome dang MPG's! over 25 average, 70% highway, 20% City, 10% playing down windy roads
+Feels more & more powerfull as miles add up.
+Still won't drive my other car, not even to work... Once I walk out and look, I go straight for the G; I will stop that soon cause the miles are adding up... Just kidding! I gotta drive my G, can't stand it, I'm addicted to her
Dang almost forgot these and they are probably the best ones:
*Still have original clutch and it's solid, no complaints.
*I still have my original Brembo pads on all 4's (yes I have cleaned my rims 1,000,000, times, LOL. Can't stand em' dirty
Those last 2 have surprised the hell out of me
Old Mar 8, 2006 | 01:49 AM
mannyh316's Avatar
05 CPE 5AT
rattle from gear box or passenger side fixed @ 2k mi
Old Mar 8, 2006 | 02:33 AM
ZLUJ's Avatar
Mmhm...
Originally Posted by firefox
Year:2004
Miles: ~38000
Problems:
Low left speaker volume when playing CD's - radio replaced
Rear axle click - replaced with TSB
Fuel fill - fixed at the dealer with TSB
Driver window loose and shaking - dealer tightened it and added lubrication
Clicking from suspension - replaced passenger side sway bar links.
Rattle coming from upper glove box - used thick padding behind upper glove box
Rattle from shifter - fixed with felt
https://g35driver.com/forums/g35-sedan-v35-2003-06/79805-diy-2003-2004-g35-sedan-rattle-exorcism.html
Rear view mirror rattle - took apart and used silicon glue to fix
https://g35driver.com/forums/interior/51690-rearview-mirror-rattle-fixed.html
Rear deck rattle - bringing into the dealer
can i see more pictures of your wheels/car? please
05 coupe:
rattles-
rear axle (clicking)
a rattle from somehwhere outside the car constantly, its very quiet but its rattling all the time -_-.
thats it
Old Mar 8, 2006 | 08:37 AM
  #30
GTScott's Avatar
Year: 2006
Miles: 1,100
Problems:
1) Brake pedal clicks when pushed - have been told this is normal
2) Creases in driver's seat leather with less than normal wear
3) rattle in driver's side door panel - will take it in for this one
4) somewhat difficult 1-2 shifts
-GT
