Year / Mileage / Problems
Old Mar 8, 2006 | 01:29 PM
  #31
new35's Avatar
Thumbs up 04/31,000 miles
2 window motors around 20,000
complete front brakes at 26,000 (warranty)
dirver side regulator and window motor 28,000 ( glass starting to scratch)
Rear rotors turned and new pads @ 29,000 (warranty)
left rear axel bearing , noisy ( replaced warranty)
currently at 31,000+ and rolling with "snows'
service at Quirk Infifniti has been excellent.... feel bad for some of you guys....who dont get the "infiniti expierence"
Old Mar 8, 2006 | 05:09 PM
  #32
redwillow's Avatar
20 Year Member
03 6 spd - 30 k miles
1.) leaky spoiler (dealer installed aftermarket) - fixed - replaced trunk & spoiler with OEM
2.) drift to right - fixed w TSB
3.) driver & pass side window problems - fixed for now, more window motors have been put in this car than i can count
4.) uneven tire wear on fronts with 18s and mich pilots - I replaced 18s with OEM 19s and bridgestone tires - wear is much better now. Michelin tires = not good.
5.) gas tank fill problem - fixed TSB
6.) rear deck rattle - fixed w TSB
7.) horrible noise from front of car - driver side bearing assbly replaced under warranty
8.) strange noises/squeaks from clutch pedal - assembly replaced under warranty - better now, but still squeaky.
9.) outside temp not reading correctly - warranty fixed w new sensor.
10.) driver side door lock stopped working - warranty fixed w/ new door lock motor
11.) screech noise from rear - fixed with axle TSB
12.) headlights cracked inside - replaced under warranty but cracked again
13.) other minor rattles, etc mostly fixed by warranty.
I am sick of taking this car to the dealership.
Old Mar 8, 2006 | 11:56 PM
  #33
bocatrip's Avatar
REDWILLOW........Don't forget that you own the first production year of this car which usually has the most problems. I'm sorry to hear of your issues but many 1st production year cars experience the same thing. Let's see how well the M fairs after a few years goe by.
Old Mar 9, 2006 | 12:10 AM
  #34
I Scare's Avatar
Unhappy Problems for a 35k+ car?
For a 35K~ car, there seemed to be so much problems. Seems like the majority of the people here have the common problems with rattling noises. I hope the manufacturer made some changes and improvement on the 06 models, otherwise i'll be seeing myself posting some of my problems too. I hope not. *crossing fingers*
Old Mar 9, 2006 | 12:22 AM
  #35
nightrider's Avatar
o6 coupe!! 9K
problem: none
Old Mar 9, 2006 | 08:51 AM
  #36
rick505's Avatar
way too many problems for a car in this price range. while i honestly enjoy my g (2005 5AT), it would probably be my last.
Old Mar 9, 2006 | 09:12 AM
  #37
SweetNlow's Avatar
City that Never Sleeps
2005 6MT /Bought it new in April 05
1. Blown engine/ Piston shot right out. (Yes I had my oil changes on time)New Engine installed.
2. Fuel pump sensor died. Replaced.
3. Current mileage 16,003
Old Mar 9, 2006 | 10:11 AM
  #38
conesweeper's Avatar
Year: 2005 6MT
Miles: 16K
Problems:
- Passenger seat rattle - Not fixed, it comes and goes.
- Driver side, left ac vent rattle - Not fixed, its always rattling.
- Driver side window ticks when 1/3 open and going over bumps - Not fixed.
- Rattle in front driver and passenger door panels with music - Not fixed.
- Oil consumption since 3k miles (Burning 1qt/1k miles) - Replaced shortblock under warrenty, not sure if its fixed yet
Old Mar 9, 2006 | 11:40 AM
  #39
FI'ed G's Avatar
05 6MT Coupe/ 6500
1. Driver Side window motor replaced
2. F'ing back seat rattle ( I think it's the cheap plastic Lock on the back seat)
3. Axle clicking (I'll bring it one day)
4. My wife slam the passenger door and hit the wall and create dent and chipped the Paint
Old Mar 9, 2006 | 03:18 PM
  #41
bocatrip's Avatar
Originally Posted by CPALIU
I hope this isn't the general concensus as I will be purchasing a G35 6mt any day. It can't be as bad as my Honda Accord though, that thingg was full of problems
I'm shocked!!!!!! Honda Accords are supposed to be great cars! I have not heard anything bad about Honda Accords or Toyota Camrys other than the lack of any drama.
Old Mar 9, 2006 | 04:46 PM
  #42
Meeno24's Avatar
2006 MT, 8K miles, No problems
Or maybe there's squeaks and rattles that I just can't hear cuz the radio and rpm's are too high.
Old Mar 14, 2006 | 06:10 PM
  #43
GForceSC's Avatar
Drivers Seat
Drivers seat has a pop in it when accelerating ot stopping. Been to the dealer (Bradshaw Infiniti, SC) 5 times. The last time the DTS came out and found a stripped bolt that anchors the seat to the floorboard. Replaced seat, lift link, welded the anchor nut and still the pop is there. 2004 G35 Sedan 10,800 miles. I also have the rattle in the rearview mirror.
Old Mar 14, 2006 | 08:36 PM
  #44
Moss's Avatar
Year: 2004
Miles: 17.5k Miles
Just 1 problem: Front wheel alignment with the "whomp, whomp, whomp" sound between 20 & 30mph. Right front tire slightly feathered. Dealer (Bradshaw Infiniti in Greenville,SC) swapped and remounted the fronts and did an all 4 wheel alignment as a courtesy. "Whomp, whomp" is still there to some extent but they tried. Otherwise, no problems whatsoever. No squeaks, rattles, bumps or grinds.
Old Mar 14, 2006 | 11:17 PM
  #45
accordfreak's Avatar
production march 2004
1) drift right- rod replaced +alignment
2) rear axle click need to take it in
3) window doesn't go down when opening the door- somewhat fixed
4) right wheel squeek going 30-40mph for long periods. not fixed
5) fuel fill- need to take it in
6) engine hiccups/ pops during idle- need to take it in
7) cracked driverside headlight- need to take it in
8) slight wind whistling noise driverside window aprox 70 mph. need to take it in.
