Oil Leak on a 06 coupe?
Old Mar 15, 2006 | 11:20 AM
richboy's Avatar
MORE POWER PLZ!!!
Will just today i went outside n started my car then took off and i saw there where oil marks on the floor. But im thinking how could my car be leaking oil i got my oil chnage at 1,200 miles and now i have 2,500. so what gives?
Old Mar 15, 2006 | 11:48 AM
Real_G's Avatar
An Army of One...
get down and look under the car and see if it is coming from your car..
Old Mar 15, 2006 | 11:50 AM
drunkin master's Avatar
maybe they forgot to tighten the lug nut. I would take it back to the place that you got the oil change from. If they don't know take it back to the dealer. good luck.
Old Mar 15, 2006 | 12:27 PM
vjquan's Avatar
Your name says it all - you must be drunk!
Old Mar 15, 2006 | 04:46 PM
prncefknchrmn's Avatar
bwaaaaaaahahahahah^^^^
Old Mar 15, 2006 | 06:59 PM
TimW's Avatar
odds are they didnt replace the crush washer. The torque used on the drain plug at the factory is enough to destroy the crush washer for re-use. (not to mention the oil filter). Or they overtighened it themselves and deformed it. Thats not very likely, but maybe the hulk was working that day.
If you use 28-32 ft lbs on it, it will last quite awhile. Tightening as hard as you can a time or two and there will be leaks.
I'd love to watch how they try to put a new washer on without completely draining your oil
Old Mar 16, 2006 | 12:11 AM
partyman66's Avatar
They may have forgotten to put on the drain plug washer. It's also a possibility that some dirt or debris is caught between the seal of the oil filter and the mating surface of the engine. You're supposed to make sure that surface is clean and smooth before putting on an oil filter, but I highly doubt that most places actually do that.
You should be able to tell where the oil is coming from by putting a piece of newspaper under your car to catch the dripping oil, and watching for where the oil shows up on the paper, then tracing it back up into the engine above the oil spill location.
Are you sure the oil wasn't from another car that was parked in the spot that you were in prior to your car being there?
Old Mar 16, 2006 | 02:15 AM
richboy's Avatar
MORE POWER PLZ!!!
IM not sure thats why i parked at a different spot today.If oil leaks does it leak every night or could it vary?
Old Mar 16, 2006 | 03:34 AM
TAR82's Avatar
++1
Old Mar 16, 2006 | 10:18 AM
partyman66's Avatar
If oil is leaking out of your car... I would think it should do it most of the time, unless it's a temperature related leak. If you live in an area where it gets extremely cold or hot, the metal on the oil filter(as well as the seals) will shrink or expand a bit. This could open up the potential for an existing leak to seep more oil, whether it's a hole in the filter, a leaking seal or anything else.
I'm going to take a wild guess and say that the oil was from another car. Oil is tricky like that, because it might look fresh while it's sitting on the tar for a few days... since oil doesn't evaporate like water would.
It's important to make sure that your crankcase sump oil level isn't dropping though, since that's really what's most important.
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
