5th gear grind
Old Mar 16, 2006 | 10:21 AM
Rookie84's Avatar
5th gear grind
It happens sometimes when I'm shifting fast on cold days. I thought about taking it to the dealer but I know for sure that I won't be able to duplicate it... I think I'm gonna mention it anyway when I'm taking my car in for rattle in dash and oil change. Would the dealer be able to find the problem at all? I heard a lot of people having 5th gear grind so I'm guessing this is a common problem? Thanks in advance.
Old Mar 16, 2006 | 12:49 PM
g35kid18's Avatar
ya im having the same problem when im higher in the rpm range and i shift into 5th it kind of grinds it just doesnt feel right and the only way i could prevent this problem is if i double clutch it.
Old Mar 16, 2006 | 01:32 PM
GsUpHoesDown's Avatar
same here...
Old Mar 17, 2006 | 12:13 AM
JDM V35's Avatar
Mine also does that in 5th at high RPM's and I have low miles 14,000 on mine.
Old Mar 17, 2006 | 01:22 AM
Maximus's Avatar
I get difficulty getting into 5th sometimes...i cant tell if its a grind though. Ive heard it may be the syncrhos, which is why it does it sometimes and will not do it other times
Old Mar 17, 2006 | 02:39 AM
escobar929's Avatar
mine def just grinds. it goes in fine but makes a nasty grinding noise. gonna try to take it in next week. hope i dont get too much crap, has any1 gotten this fixed?
Old Mar 17, 2006 | 10:57 AM
I haven't taken mine in yet. The dealership is probably going to give me crap for changing all the diff and gear fluids myself. I used all synthetics that were all within specs, but you know how stealerships are...
Old May 11, 2006 | 04:28 PM
supra2k's Avatar
yea, mine def goes in too, i've had mine replaced twice, and it's doing it again. IT grinds as i shift into 5th and 6th gear. I need to have them fix it again, Should i have it fixed then install my act clutch? or will they blame the clutch? Thanks
Old May 11, 2006 | 06:27 PM
papagz's Avatar
^^ get it fixed then install the clutch. ive had 2 replacement transmissions already. going in AGAIN for the 3rd time, this time using a lemon law lawyer. its common, but tranny can be replaced
Old May 12, 2006 | 05:21 PM
GISMO35's Avatar
My car is at the dealer today for the 30k service and to see about the difficulty I have getting it into 5th gear. Hopefully they can duplicate the problem when they test drive. It's a random thing.
Old May 12, 2006 | 06:15 PM
AestheticMynd's Avatar
Sounds like bad syncro issue?
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
